Doing a good between centres job on a round bar is a big challenge
Doing a good between centres job on a SQUARE bar is a heck of a challenge
I've never seen one done before in anything I've ever read
Workholding would be made a lot easier with a longer than required square bar
Turn each end into roundbar and hold between centres with two four jaw chucks?
Each chuck jaw should be parallel with one side of the square bar
None of the Above can happen until you get a spot-on centre hole at BOTH ends, or disaster will happen, the sides of the square bar will be misaligned when its on the lathe
Truly accurate 2nd operation jobs are a PITA
Bear in mind that you can also combine Two bespoke dead centres with the 4 jaw chucks, since they will fit down the centre of each chuck into the mandrel taper, this may help….
A heck of a challenge IMO
GL
Edited By Ady1 on 07/03/2014 08:43:59
