Pre-war Italian thread ?
Home Forums Help and Assistance! (Offered or Wanted) Pre-war Italian thread ?
  • #782477
    Tim Stevens
      @timstevens64731
      I am working on a pre-war Marelli Magneto, and it has several screws 5.5mm diameter x 0.9mm pitch. My references cover UK, French, German and SI metric and I cannot find a match. Some of the screws have been attacked with screwdrivers which did not fit, and the heads are butchered.
      Can you help with exact identity, or replacements (about 20mm or longer, domed countersunk heads) or even tap & die? – thanks
      And happy Valentines Day to you all.
      Tim Stevens
      Welsh Marches – UK
      David Jupp
        @davidjupp51506
        Could it possibly be 1BA?  Without knowing the history, it’s a bit of a guess – but the design could have been licensed in from elsewhere.  Hence may not have been an Italian thread at all.
        #782493
        noel shelley
          @noelshelley55608
          5.5 x .9 is a metric size and taps an dies are available from Tracy tools, or it may be 1 BA at 5.3 x.9. Good luck. Noel.
          #782501
          Howard Lewis
            @howardlewis46836
            1 BA is 5.3 mm dia and 0.9 mm pitch, as already intimated.
            Being Magnetti Marelli, and so electrical, quite a possibility, IMO
            Howard.
            #782503
              5.5 Loew is 5.5 x 0.9
              Close to 7/32″ x 28 BSF or #12-28 UN
              #782523
              Nimble
                @nimble
                Hi Tim,
                Perhaps you could contact “The Magneto Guys”  https://www.themagnetoguys.co.uk/  .
                They seem to be pretty good about giving out information.
                Good luck.
                Nimble Neil.
                #782601
                Tim Stevens
                  @timstevens64731
                  It could indeed be 1BA, except that the measured od of the screws is a bit larger. So, properly speaking, 1BA is what I need, as the profile of the thread is unique with angles of 47.5 degrees between the flanks. So, who makes or sells 1BA screws – preferably in stainless steel?
                  Thanks David – I never thought to check if BA was used, as it is only found (in my experience) in models, and old electrical plugs etc.
                  Tim Stevens
                  #782603
                  bernard towers
                    @bernardtowers37738
                    If you only need a few it would be simpler to make them yourself.
                    #782605
                    noel shelley
                      @noelshelley55608
                      In answer to who makes/sells 1 BA try EKP Supplies. Good Luck. Noel.
                      #782715
                      Stuart Smith 5
                        @stuartsmith5
                        My friend is restoring an old Italian motorbike and was struggling to find some M7 bolts.
                        After searching everywhere, he eventually obtained some from a local shop in Preston. (Allthread fasteners).
                        This is the link to their website:
                        https://www.atfltd.com/
                        Worth asking them.
                        Stuart
                        #782730
                        Circlip
                          @circlip
                          Rear brake linkage to master cylinder is an M7 thread on me Guzzi Le Mans, ended up thread cutting it meself from 304.
                          Regards  Ian.
                          #782751
                          Charles Lamont
                            @charleslamont71117
                            M7?  Every day is a school day.
                            #782754
                            noel shelley
                              @noelshelley55608
                              M7 x 1 is a standard metric thread and commonly available, but not a preferred size !
                              If the screw is a big 1 BA ( oversize ) then UNLESS your sure it is 47.5* thread angle it will be 5.5 X .9, a normal metric thread. Wear and machining tolerances may well allow both to fit. Noel.
                              #782796
                              Martin Connelly
                                @martinconnelly55370
                                Personally I would just get out my metric thread gauges and try the 0.9 gauge against a screw with a light behind. This will quickly show if it is a BA thread because there will be lots of light showing if it is. If you intend to do work on equipment with unknown threads then thread gauges seem to me to be a good investment.
                                Martin C
                                #782798
                                Speedy Builder5
                                  @speedybuilder5
                                  M7 – Citroen 2cv all over the place, engine, chassis etc.
                                  Bob
                                  #782802
                                  Speedy Builder5
                                    @speedybuilder5
                                    1Ba, if you have a model steam loco club nearby, Ba are used extensively on the older models and plans – not stainless though (unless you are very lucky). Mind you, domed CSK are a bit rare!
                                    Bob
                                    #782818
                                    bernard towers
                                      @bernardtowers37738
                                      As I said earlier you could have made them by now.
                                      #782886
                                        Tim doesn’t have taps or dies and we don’t even know what the thread is yet. Five possibles suggested and it could be continental or even non-standard. I’d order a few 1BA and M5.5×0.9 in hope one will fit.
                                        Martin Connelly
                                          I had to make a couple of screws for a friend who restores large music boxes. Many were made in Italy, Switzerland and that general area. The thread on those screws was a Löwenherz thread form and one of the listed sizes is Ø5.5×0.9 pitch. I think a quality photo zoomed in from a distance against a plain background is needed for the angle of the thread to be measured, much like a shadowgraph. Just guessing when there are so many possibilities is not going to achieve much. There is a possibility of forcing an incorrect thread form into the hole and it putting excessive unusual strain on a hard to replace part.
                                          Martin C
