Pratt Burnerd 4 Jaw Chuck
Home Forums Manual machine tools Pratt Burnerd 4 Jaw Chuck
  • #568004
    Len Morris 2
      @lenmorris2
      Hi Everybody,
      I have a PB 6 inch 4 jaw chuck in need of some TLC. I'm not sure how to remove the forked pins that retain the jaw screws. They have no obvious fixing on the chuck back face. All that's visible are the flat ends of the pins. I suspect they just press out but would like to know for sure before I start forcing things. Can anyone help?
      Thanks and regards,
      Len
      Len Morris 2
        @lenmorris2
        #568007
        DC31k
          @dc31k
          They are a tight fit in their holes. No other method of retention.
          It is prudent to keep pins, jaw screws and slots together so they go back in the same way they came out. If really fussy, mark rotational orientation as it would be possible to reinstall 180 degrees out.
          Examine them well and stone off any burrs resulting from the removal process before reassembly.
          Beware on reassembly that if the forks are twisted (rotated) it can make operation of the screw very tight.
          Reassembly can be made a little easier if the chuck is warm and the pins are cold.
          #568010
          Dave Halford
            @davehalford22513
            I tapped mine out with a hammer and knackered screwdriver.
            #568019
            Len Morris 2
              @lenmorris2
              Hi,
              Thanks for those quick replys. I can now get the pins out with confidence on the fly press. I'm not a fan of press fits on items that need regular cleaning and so intend to lap the pins for a sliding fit and lock them axially in place with cap screws leaving them free to rotate for fork alignment. Petty much the same as with larger 4 jaw chucks.
              Best regards,
              Len
              #568020
              Dave Halford
                @davehalford22513
                Len,
                The backplate holds them in.
                #568039
                Brian Wood
                  @brianwood45127
                  Len,
                  Be aware that they are hardened, it might well influence your holding method and it would be interesting to know how you intend to hold them for lapping.
                  You might want to change your mind. the method used by Pratt is long established.
                  #568047
                  Len Morris 2
                    @lenmorris2
                    Hi all,
                    Agreed the back plate stops the pins dropping out but it would allow too much axial slop for my liking. I know the pins are hardened but I've found that modern tooling takes the fear out of that. I've not got the pins out yet so don't know how I'll hold them. For an easy life I might just polish them and relieve the holes in the cast iron body. As far as I can see, the method used by Pratt on this chuck is cheap and nasty and just allowed them to save a few pounds on its production.
                    Anyway, thanks for all your comments. I now know how to get the pins out and will post some pics and comments on the final job.
                    Best regards,
                    Len
