Posted by Andrew Johnston on 18/02/2021 10:23:57:
Was the buck converter unloaded during the measurement? It's common for simple switchmode power supplies to lose regulation on light loads, or no load.
I was thoroughly confused by the switch mode power supply in a work-light, providing 12V to a car headlamp bulb. It misbehaved due a an intermittent connection. Unloaded, the PSU appears almost completely dead, barely twitching the needle on my multimeter's 0.5V range. With a 55W bulb correctly fitted, bursts into life – 12V. Deliberately or by accident the power supply doesn't work unless it has a load.
On the subject of stepper power supplies, I use the LED type because they're cheap and easy to find. They're not ideal because a stepper likes lots of volts and quick bursts of current. An ordinary unregulated PSU is more suitable because a voltage stabilised power supply might have trouble keeping up with the motor's wild demands, and because starting pulses with a high voltage is an advantage. In practice, I've not had any trouble with LED PSUs and they are easier to buy than old-fashioned unregulated PSUs with an expensive transformer.
Edited By SillyOldDuffer on 18/02/2021 11:25:09
