power supply for organ
Home Forums Electronics in the Workshop power supply for organ
  • #31895
    duncan webster 1
      @duncanwebster1
      duncan webster 1
        @duncanwebster1
        The topsy type organ I've built needs 12v @ 1.6A to drive the pallet valves and decoder and 24v @ 1.5A to drive the fan. I'm currently running it on a 0-12-24 transformer (nominal). Smoothing the 12V gave too high a voltage for the decoder, so that has a 12v regulator (7812), and the 24V to the fan is controlled by a variable mark/space ratio controller. The transformer is all a bit heavy.
        I've searched the interweb for a 0-12-24 switch mode supply to no avail. I'm now proposing to buy a 12v @ 5A switch mode **LINK**
        and feed the fan controller via a second 12-24 switch mode booster. I can then get rid of the 12v controller. Can anyone think of a reason this won't work? Do I need a capacitor between the 2 switch modes to provide some reserve?
        #311472
        Martin Kyte
          @martinkyte99762
          Can you not get 2off 12V floating output supplies and stack the outputs.?
          regards Martin
          #311474
          Keith Rogers 2
            @keithrogers2
            Hi Duncan,
            Why not get a 24v Power supply and drop to 12v with your regulator.
            (you'd probably need a heatsink)
            Keith
            #311478
            Les Jones 1
              @lesjones1
              I would suggest getting a 24 volts switch mode regulator of at least 3 amps rating and a switch mode regulator module such at this to regulate down to 12 volts. Using the switching regulator to drop the 24 volts down to 12 volts avoids having to disipate about 20 watts in a linear regulator. You can get these modules cheaper direct from China but it takes about 4 weeks.
              Les.
              #311485
              Bazyle
                @bazyle
                Just no sense in using one psu. 12v powerplugs are dead common as just about every techie toy uses 12v so volume = cheap, say £5. 24v is a lot less common but available for under £15. This also keeps fan motor noise off the electronics.
                Alternatively have a look at 3D printer websites a they want electronics at low voltage and a higher level for the steppers.
                #311494
                  +1 for Les' solution.
                  #311511
                  duncan webster 1
                    @duncanwebster1
                    Martin, I'd need 12v at ~4A plus 12v @ ~2 A, so certainly no cheaper than my solution
                    Keith, I'm trying not to have a linear regulator pumping out about 18W. The one I've got should by rights have died by now, it is working above it's nominal max current
                    Les, your solution seems to be very similar to mine except if I start with 12v I can run off a battery if I need to, plus I've already got the 12 to 24 left over from a previous project, I just wanted to know if there was an issue running one inverter off another
                    Bazyle, I like that idea, I'm looking into 24v supplies, not as rare as I had imagined, and about £11.50
                    Thanks for all your replies
                    #311513
                    Les Jones 1
                      @lesjones1
                      Hi Duncan,
                      I have to confess that I did not read you first post fully. I see no problem with what you propose. The only think I would say is that you will be running the 5 amp (60 W) power supply above it's rating. If we assume 80% efficiency in the boost converter then it will take 3/0.8 = 3.75 amps at 12 volts and the rest of your 12 volt load is 1.6 amps so 1.6 + 3.75 = 5,35 amps. I notice that the advert offers an 80 watt unit (6.66 amps.) so that would be a better choice. (And 50p cheaper)
                      Les.
                      #311554
                      duncan webster 1
                        @duncanwebster1
                        Les
                        I'm glad I read your post carefully. Prompted me to actually measure the input current to my boost converter. 4.8A with the motor on full chat drawing 2A, which I suppose isn't that bad. I'd forgotten that step up draws a lot more than the output, if it didn't we'd be into perpetual motion. If I'd gone down my planned route I would have released the magic smoke. I'm adopting your approach with one of these **LINK**
                        and the step down thing you suggested.
                        Thanks again
                        #311903
                        Martin Kyte
                          @martinkyte99762
                          Posted by duncan webster on 11/08/2017 17:40:45:
                          Probably. I was really pointing out that you can 'stack' floating output switch mode supplies like batteries to obtain different supply rails.
                          regrads Martin
                          #311904
                          Nick_G
                            @nick_g
                            Jasons Tidman organ steam engine was designed for such originally. cheeky
                            Nick wink
                            #313330
                            Martin Newbold
                              @martinnewbold
                              You said you cant locate a switch mode supply have you tried RS Electronics
                              #313346
                              duncan webster 1
                                @duncanwebster1
                                I've implemented Les's solution, but laptop has now died, so I'm fighting to get my new one to do what I want. They don't make it easy, but I have several willing friends who understand these things
