power supplies for arc euro steppers
  • #14939
    razza
      @razza
      razza
        @razza
        just bought a 350ncm bi polar stepper and driver card from arc euro trade
        im trying to figure out the power supply i need for this can anyone shed any light on this setup as instructions state that the current is 4.2 amps per phase so this seems to mean i need a 8.4amp power supply but on other side of sheet it says the arc eurotrade 160-020-00201   9.04a   controller will drive this motor at the rated power if set up correctly and connected toa smoothed dc power supply rated at 2x the the current setting used on the controller
        so does this mean i need to set the controller to 4.2amps and power supply of 8.4amps
        or set the controller to 8.4amps and a power supply of 16.4amps
        if someone could shed some light on this it would be much apreciated
        regards mick
        #59504
        john swift 1
          @johnswift1
          Hi Mick ,
          you only set the motor current on the stepper motor driver
          provided the power supply can supply  the total current needed ( 8.4A in your example  )
          you just to make sure the output voltage is within the range of that required by the driver
          (usually between 24v and 80v )
           so you could use for example a 60V 15A power supply
          If you use an unregulated supply , you need to ensure the off load vottage is not
          more than  the maximum for the driver ( its better to stay several volts under the maximum)
          Edited By john swift 1 on 27/11/2010 20:39:12
          Edited By john swift 1 on 27/11/2010 20:39:51
          Edited By john swift 1 on 27/11/2010 20:42:54
          #59519
          Weldsol
            @weldsol
            Hi Mick have a look at this site
            This is where I got all my motors / drivers / power supplies from
            Paul
            #60028
            razza
              @razza
              thanks guys seems clearer now
              regards mick
              #108364
              M.Marino
                @m-marino
                For those motors the Voltage would be a maximum of 59.8665V @ 8.4A should do you just fine. The formula I used is V= 32 * sqrt L (mH) so 32 * sqrt3.5 = 59.8665 approx. Hope this helps. Since that is an odd size you would be looking to build a power supply or deal with the motor being under powered.
                Michael
                #108370
                Terryd
                  @terryd72465
                  Hi Mick,
                  You could do worse than to look on the ARC Eurotrade site itself.
                  Terry
