Thanks to all for your input.
Neil, and Muzzer. You have given me a better idea of the "why" of it, thanks. Yes this switch will be to just cut off the current drain while the bike is stored so the contacts have just got to be robust enough to carry the load to the instrument panel and IC while the bike is starting/ running. I suppose I should check out the maximum load through it with an ammeter before I do anything.
Nathan, I have boughtt one of those switches but they are quite large and clumsy, more suitable for under the bonnet of a Land Rover!
Thank you for the link, V8Eng. I will have a look at the site. I knew though that I would learn more by throwing out the question to the Forum.
Alan, I have one, but last winter I thought that I'd top up the charge once a week or so. Well, due to senior moments in that regard I have now got a new battery fitted! You are of course right about the charging regime but I just don't like leaving electrical gadgets plugged in, but point taken.
Edited By Breva on 19/05/2015 23:29:07
