Hi Andrew Trolled up a bit of info on Qualters And Smith Power Hacksaws.
The Bulldog 150 can be viewed working here-
http://www.youtube.com/watch?v=isuPXWE1wyM
Features
Totally Enclosed Drive
Two Cutting Speeds
Fully Adjustable Feed
Hydraulic Relief on return Stroke
Bow raises automatically and stops motor on completion of cut.
Heavy Duty Quick acting vice allows location to be made of 90-45degrees
Adjustable Bar Stand
Safety features
The machinery drive doors if opened when the motors are running ,the motors will stop by safety switches on each door
Emergency stop on the starter
Automatic motor stop after the saw bow has raised to its start position
Specification
Main motor :3ph 1hp
Coolant motor :3PH 0.8
Speed:100 and 150 strokes /min
Capacity : @ 90degrees 150mm :@ 45 degrees 90mm
Weight : 280kgs approx.
Sawblade:14" x 1 " Size : 46.75" (1.187mm) L x 20.5"(520mm) W x 36" ( 914mm) H approx.
