Hello,
I obtained a Qualters & Smith Power Hacksaw.
The motor switch was not working. It was the original switch made by MEM. One of those older electro-mechanical switches, were a transformer breaks/connects the circuit.This MEM switch also had thermal protection.
The motor is 3 phase. I decided to replace the MEM switch with a modern motor switch with thermal protection, as I could not find a replacement on ebay with the right amperage.
I purchased a Schneider motor breaker with thermal protection
http://www.ebay.co.uk/itm/Thermal-Magnetic-Motor-Protection-Starter-Schneider-Up-to-15kW-1-or-3-Phase/272713903327?ssPageName=STRK%3AMEBIDX%3AIT&var=571849511183&_trksid=p2057872.m2749.l2649
I connected it up fine.
Now on this power hacksaw there is a limit switch actuated by a cam so that the saw cuts off once the saw reaches the bottom or top. The plan was to connect the cables of the limit switch to one of the 3 phase cables so that when the limit switch is pressed down one of the 3 phases cuts off. So that is what I did and Yes one of the 3 phases I selected to connect the wires of the limit switch does cut off when the limit switch in pressed down.
Well the problem is the motor will still run with only 2 of the phases connected to it. So my original thinking that I could shut down the motor by switching one of the phases off with the limit switch is completely wrong.
I need to break the circuit completely, all 3 phases, onece the limit sitch is actuated.That is what the original MEM switch was doing.
So how do I actually do this?
