Power feed – ‘which motor shall I buy’?
Home Forums CNC machines, Home builds, Conversions, ELS, automation, software, etc tools Power feed – ‘which motor shall I buy’?
  • This topic has 35 replies, 14 voices, and was last updated 24 May 2020 at 17:13 by Brian Rutherford.
Viewing 11 posts - 26 through 36 (of 36 total)
  • #473502
    John Baron
      @johnbaron31275
      Posted by Robert Atkinson 2 on 21/05/2020 07:40:03:
      Why have you got a tumbler reverse gear on a drive from a reversable motor?
      Robert G8RPI.
      Because the wiper motors are designed to run in one direction only. The worm only has a thrust bearing at one end.
      Martin Connelly
        @martinconnelly55370
        I think 10mm wide 5mm pitch timing belts will be fine (from experience).
        Martin C
        #473524
        Stuart Smith 5
          @stuartsmith5
          Posted by old mart on 20/05/2020 20:54:48:
          Whatever you make, be sure it costs less than the purpose made power feeds which go for about £ 130.
          Where can you buy one for £130? The only ones I have seen are at least £280, mostly £300+.
          Stuart
          #473549
          Robert Atkinson 2
            @robertatkinson2
            Posted by John Baron on 21/05/2020 10:23:19:
            Robert G8RPI.
            You could just put a bearing at the other end. A single ball for the spindle to thrust on would be good enough. Then you can auto reverse electrically. With tumbler gears you will have to stop rhe motor,move gears and re-start the motor.
            Robert G8RPI.
            #473569
            John Baron
              @johnbaron31275
              Posted by Robert Atkinson 2 on 21/05/2020 13:29:25:
              Why have you got a tumbler reverse gear on a drive from a reveresable motor?
              Robert G8RPI.
              You could just put a bearing at the other end. A single ball for the spindle to thrust on would be good enough. Then you can auto reverse electrically. With tumbler gears you will have to stop the motor,move gears and re-start the motor.
              Robert G8RPI.
              Hi Robert,
              It might pay you to look at how a window screen wiper motor is constructed. That is after you have drilled all the rivets out !
              #473612
              Robert Atkinson 2
                @robertatkinson2
                Posted by John Baron on 21/05/2020 14:15:49:
                <SNIP>
                Hi Robert,
                Hi,
                I've looked at plenty of wiper motors over many years and fixed more than a few.
                The one pictured in your album is typical, Adding a thrust ball to either the pressed steel motor cover or the cast alloy gear case should not be too difficult. Typically its the motor end that has no thrust beraing, typically just a self aligining (bll shaped) oilite type bush. There is normally enough room in the back of the housing to hold a suitable sized ball. A spacer / locator might be required but that's about it.
                Robert G8RPI.
                #473641
                old mart
                  @oldmart
                  I was mistaken about the current price, in the last few months prices have rocketed, maybe due to CO19. This is the cheapest I could find, and the buyer risks paying more if they are unlucky with import duty additions. Of course, you would still have to carry out a lot of modifications to make any of them fit your machine.
                  Edited By old mart on 21/05/2020 17:04:55
                  #473679
                  Iain Downs
                    @iaindowns78295
                    Thanks for all the help. As I remarked to Brian, I enjoy designing and making tools like this much more than using them. The journey is the destination.
                    I'm sticking with my approach – cheap and cheerful stepper supported by bits I already have. I spent some of last night designing how I'm going to connect stuff up and will post here for comment when I've got something complete.
                    Basically I still want to be able to use the handle, but I also want to be able to disconnect the motor if I need.
                    More to follow (but not toinight).
                    Iain
                    #473684
                    John Baron
                      @johnbaron31275
                      Robert G8RPI.
                      Robert G8RPI.
                      If you are daft enough to start taking a well engineered wiper motor apart just to stuff a bearing ball in there, then good luck.
                      You keep can keep the last word !
                      #474532
                      Brian Rutherford
                        @brianrutherford79058
                        By the way Iain the mill table weighs 42kgs. Weighed mine this afternoon.
                        #474533
                        Brian Rutherford
