Thanks for an interesting and informative discussion.
The 64,000$ question beyond the need to maintain the CCTV is what of her devices don't automatically reset after a power cut. I suspect the need for continuous CCTV and associated internet connection is indeed, as V8Eng says, to help keep the insurance company happy.
So Plan A will be to look into one of those battery back-up, multiple 12 V output, boxes like this :- **LINK**
https://www.ebay.co.uk/itm/323995263949 Electrical CCTV Camera Power Supply Box 5/9/18 Channel Back Up Battery Option
Which should keep the surveillance kit and internet connection live. Possibly also any other 12 V kit that doesn't auto restart properly.
Dunno about her gas boiler and control. Its fairly recent install but so is mine and that needs manual intervention to bring it back up after a power cut. Mains back driving isn't really an issue if the system always runs off the battery via the inverter with a float charge system to keep it charged when the mains is on. So its fully isolated via the charger.
I'm a little surprised that the big battery system that Samsaranda has on his solar panels doesn't automatically handle the mains disconnection and reconnection thing as it seems fairly simple to implement. Basically whacking great normally open relay held on by mains power with a suitable control delay before reconnection! Something I need to look into when I get a battery system for my panels.
The big surprise for me was just how much battery you need to keep CCTV up and running for decent periods. Its clear that normal UPS systems aren't made for this job. To get the battery capacity you need something with a silly oversize inverter on the output end as common specification is only 10 minutes or so at full load.
The camping systems are interesting but I'm skeptical of reliablity on permanent float duties.
Thinking I really need to get my generator permanently linked in just in case. One of the uber quiet Honda EX5500 beasties with a twin cylinder water-cooled engine. Old but much less noisy than anything modern.
