Powder coating
Powder coating
Home Forums The Tea Room Powder coating
  • #776510
    John MC
      @johnmc39344
      I want to fill some imperfections in a number of steel parts before having them powder coated.  My understanding of the process is that the part needs to be electrically conductive so the powder sticks.  Traditional body fillers, Isopon etc., are not conductive.
      Also the heat involved, around 200deg C?   I can’t see body fillers liking that!
      Is there a special filler available?  I’ve seen something called “Lab Metal”, good for ~170deg C, supposedly good for powder coating.  Conducting.  Very expensive though.
      Solder might be a way forward, conducts and good for 300deg C.
      Any thoughts?
      David Gibbons 1
        @davidgibbons1
        all of the videos I have seen use car body filler or JB weld epoxy. seems to work for them
        #776519
        duncan webster 1
          @duncanwebster1
          Most lead/tin solders melt at a lot less than 300C (typically 180) even the lead free stuff is 217C. Comsol is higher, but I’d just ask the power coating man (unless you’re doing it yourself)
          #776574
          mark costello 1
            @markcostello1
            The people that I know that do that kind of stuff will braze up defects as a lasting fix.
            #776685
            John MC
              @johnmc39344
              Thanks for the replies.
              Brazing and soldering (HMP) both seem to be the common methods of dealing with the larger blemishes from the info I have gathered from recent investigations.
              One recurring piece of advice is to use JB weld epoxy for the small blemishes, will probably do for the rust pits I need to fill.
              As for conductivity, does seem to matter if the (non-conductive) filler is a thin layer.
              #776725
              Mick D
                @mickd41895
                Hi
                On the advice from my local powder coaters, I have successfully used alloy wheel filler, it is conductive and withstands the oven temperature they use, (206 degrees C). The brand I have used is Isopon Alloy Wheel Filler.
                Regards   Mick
                #776773
                bernard towers
                  @bernardtowers37738
                  Looking at isopons info it looks like it could be an alternative to jb weld.
                  #776789
                  Bazyle
                    @bazyle
                    Although it is probably an epoxy base be aware that some of the isopon range are actually designed to be soft (unlike JB Weld) so that they can be sanded back easily for car body repairs. I would expect the alloy wheel filler to contain powdered aluminium while JBW hopefully wouldn’t as it might promote corrosion when used on steel.
                    #777199
                    Paul Mills 4
                      @paulmills4
                      Used to work at a firm that made expensive one of f lighting, any small defects  in parts to be powder coated were filled with this
                      Superfast Steel Epoxy Putty Stick
                      easy to use and resistant to the temperatures in the coating process
