Posted by Howard Lewis on 03/02/2022 12:12:28:
When I was in the Electronics and Vibration lab, every Monday morning we would all check our resistance with the
Avo 7.
Normally from one hand to the other it was about 140K Ohms.
Under the weather, with a cold would show as 120K.. Standing on a floor insulkated to withstand 5K Volts, I inadvertently put the fingers of one hand across the Live and Neutral of a 13 amp lug. (The top came off! ) and am still here to tell the tale. 240 volts across 140K ohms gives a current of 1.7 mA., so may be I was lucky, courtesy of the floor since, electrically, I was "floating", and it was AC so the voltage fell to Zero on every cycle..
But Remember, "Its the volts that jolts, its the mills that kills"
As Martin said, Best never to be exposed to high voltages.
What makes a shock dangerous? Definitely true "volts that jolts, its the mills that kills" or "Volts that Jolts, Amps that stamps". But in addition to how much current flows, it also matters where it goes, and for how long.
How much current is said to be dangerous varies considerably depending on who you ask. I was taught at school 30mA through the heart was usually fatal, while this summary I found on the web is more gung-ho:
1 mA Perception level. Slight tingling sensation. Still dangerous under certain conditions.
5 mA Slight shock felt; not painful but disturbing. Average individual can let go. However, strong involuntary reactions to shocks in this range may lead to injuries.
6-30 mA Painful shock, muscular control is lost. This is called the freezing current or "let-go" range.
50-150 mA Extreme pain, respiratory arrest, severe muscular contractions. Individual cannot let go. Death is possible.
1000-4300 mA Ventricular fibrillation (the rhythmic pumping action of the heart ceases.) Muscular contraction and nerve damage occur. Death is most likely.
10,000 mA Cardiac arrest, severe burns and probable death.
Touching the Live and Neutral pins in a plug with one hand isn't particularly dangerous because the current is isolated in the hand. Touching Live with one hand while standing on a concrete floor is far worse because the current flows to ground across the heart. However, even a mild local shock is dangerous if the recipient falls off a ladder or into rotating machinery!
The length of time current flows matters too. When the UK adopted 240Vac 50Hz rather than 120V 60Hz, it was argued the extra-voltage and lower frequency are equally safe because it tends to throw the victim off, whereas people stay connected longer to 120V and more current flows for longer. The throwing off effect doesn't apply to 440V systems, a nasty shock is almost inevitable.
The lowest voltage fatality I know of was caused by a 32V system. A well-soaked young coal-miner was running to get out of a downpour, when he fell heavily against a corrugated iron sheet behind which was a 32V power bus used to provide 'safe' electricity to a colliery machine. Not insulated because it only 32V. Killed because:
- The miner was hot and sweaty, which lowers skin resistance well below 140k ohms
- His clothes and the ground were both soaked, reducing resistance to ground
- The contact area between human and power bus was increased by the corrugated iron sheet, decreasing the contact resistance enormously.
- Current flowed until the power was turned off manually.
As is often the case, the accident occurred when a chain of circumstances came together which is why H&S practitioners are keen to put multiple protections in place. If one protection works, the chain is broken, and there's no tragedy. Here:
- Don't run in the workplace. (The employee broke a rule.)
- Understand the need to do a proper risk assessment. Risks aren't always obvious. (The employer was found negligent due to not considering what could go wrong. The installation was described as 'slapdash'.)
- Make sure power-lines can't be touched accidentally. (Basic requirement from the earliest days of electricity.)
- The accident occurred before RCDs were invented, but they cut the power automatically.
John raised the risk of a disconnected earth wire on his Myford. Actually the same fault can occur on any machine tool, not just Myfords. Vibration is really good at shaking wires loose and chafing insulation! I always check wires and connections when I'm inside or behind a machine.
Edited By SillyOldDuffer on 03/02/2022 15:06:29
