Posh washers
Posh washers
Home Forums Materials Posh washers
Viewing 15 posts - 1 through 15 (of 15 total)
  • #29878
    AJW
      @ajw
      AJW
        @ajw
        I require some posh 2ba and 0ba steel washers, I think they are called engineering washers?
        I believe they are produced from bar stock and have a small chamfer to one face.
        Alan
        #388696
        Jeff Dayman
          @jeffdayman43397
          If you have access to a lathe, or know someone who does, why not drill and turn a mild or stainless bar to OD and ID required, chamfer to suit, part off as many as you need. Far cheaper than buying them and may be less time to make them than searching for them.
          Don't need any plating paint or oiling for corrosion resistance if you make them in stainless.
          #388704
          Anonymous
            Posted by Jeff Dayman on 01/01/2019 16:29:07:
            If you have access to a lathe, or know someone who does, why not drill and turn a mild or stainless bar to OD and ID required, chamfer to suit, part off as many as you need….
            That's what I do, although I have the luxury of a repetition lathe which simplifies production once it is set up:
            #388711
              As 0BA is 6mm OD you will have more luck finding M6 ones and may even be able to get away with M5 for the 2BA.
              Accu do both
              #388723
              AJW
                @ajw
                Thanks for replies, I know they can be made it’s just that I thought they would be easy to source!
                Thanks for link Jason.
                Alan
                #388727
                roy entwistle
                  @royentwistle24699
                  Trouble with making washers is that you make as much swarf as washers unless you can find a zero thickness parting tool
                  Roy smiley
                  #388739
                  Kiwi Bloke
                    @kiwibloke62605
                    Have you tried asking your local nut & bolt supplier for 'T&C' washers (Turned & Chamfered)?
                    #388742
                    AJW
                      @ajw
                      One of my tomorrow jobs!!
                      Alan
                      #388764
                      Vic
                        @vic
                        I’ve not needed to make any for a while but in the past I’ve made extra thick “machine washers” for clamping setups. Standard washers always seem a bit thin for this or is it just me?
                        #388779
                        Ady1
                          @ady1
                          They probbly stamp them out of strip plate nowadays
                          #388781
                          Hopper
                            @hopper
                            Posted by Vic on 01/01/2019 21:45:57:
                            Yes hardware store washers will bend etc as they are made of malleable Chinese cheesium. If you buy Grade 8 washers from a fastener supplier they will last a lifetime for clamping etc.
                            #388792
                            John McNamara
                              @johnmcnamara74883
                              Given the small size if you don't have access to a lathe.
                              Get some grade 8 washers. place them on a bolt with a nut to clamp them then chuck them in an electric drill and then carefully file the chamfer.
                              polished up with fine wet and dry paper both in the drill and on the face they should look fine.
                              “Bill Hancox”
                                @billhancox
                                Posted by Andrew Johnston on 01/01/2019 16:42:34:
                                That's what I do, although I have the luxury of a repetition lathe which simplifies production once it is set up Andrew
                                On this side of the ditch suppliers refer to these as Williams Washers. I keep several sizes under the lathe. The ones I purchase from Fastenal tend to be on the hard side which provides for an even torque without scoring or damaging the material at hand.
                                #388813
                                AJW
                                  @ajw
                                  Thanks once again, I have always called these engineering washers! and have searched accordingly.
                                  Searching for chamfered washers brings up more possibilities, I found on the bay a seller (zorotoolsuk) selling a variety of sizes and I have ordered 250 M6 chamfered steel (unplated) washers for ?5 post free.
                                  Not bad I thought!
                                  Alan
                                Home Forums Materials Topics
