Poor Hex stock
Poor Hex stock
Home Forums Materials Poor Hex stock
  • #235848
    Vic
      @vic
      I bought some 12mm bright mild Hex stock from a local supplier and I'm not that impressed with the quality of the form. Only a couple of the " corners" are sharp the remainder being quite rounded. Is this common enough or is the stuff I have sub standard? It a shame as it turns really well.
      Vic
        @vic
        #236065
        MyrtleLake
          @myrtlelake
          In my experience, all standard (i.e. not precision ground) hex stock has rounding of the points. That is to be expected. How much rounding can vary, but the overall effect should be a nice, deburred corner. Something that drastically changes the overall hex profile is unacceptable.
          I might also add this.  All the hex stock I've encountered has a uniform rounding of the points.  Your description implies a fairly dramatic variation.  That, I would find very odd and could be grounds for refusal.  Definitely worth a point of inquiry, IMO.
          Edited By MyrtleLake on 24/04/2016 21:12:41
          #236073
          Vic
            @vic
            I only bought a metre of it but point taken, if I buy any more I'll inspect it a bit closer.
          Home Forums Materials Topics
