Poly-Vee Belts
Poly-Vee Belts
Home Forums General Questions Poly-Vee Belts
Viewing 25 posts - 1 through 25 (of 29 total)
  • #428491
    ChrisH
      @chrish
      Quick query re Poly-Vee Belts. Seems they can come with a variety of variation of ribs – 4, 6, 8, 12, 16 etc. I presume selecting the number of ribs required for a particular belt is dependent on the power required to be transmitted. The question is, what determines the number of ribs required for any particular application of poly-vee belt.
      Or put another way, how does one determine how many ribs are required?
      Chris
      ChrisH
        @chrish
        #428493
        Phil P
          @philp
          As with Vee Belts there are various different sizes of Poly Vee Belts.
          Let me have your details via a PM and I will send you a PDF catalogue showing all the details.
          Phil
          #428495
          ChrisH
            @chrish
            Phil – pm sent!
            Chris
            #428499
              Dibnah
                @dibnah
                Hi Chaps
                New to the forum, have just inherited a small lathe (Zyto) which has flat cone pulleys on the spindle and countershaft. It has a flat belt with it that was stapled together but it is too wide, making only the middle pulley usable. I need to relocate the countershaft as the original setup has been lost. So was thinking, I will locate in a way that is convenient and cost effective for belts. So among these corridors has anyone run a regular poly-v belt inside out on flat pulleys ?
                ie the flat portion of the belt in contact with the pulley ? Or has anyone ran "A" powertwist on flat pulleys ?
                Thanks
                #485771
                Bazyle
                  @bazyle
                  The use of pollyv is very common normally suggested to be run inside out ie flat side to pully but also mentioned that the rubbery v inside handles more power. The disadvantage is that the spindle has to be taken out to thread it into the belt.
                  #485885
                  Dibnah
                    @dibnah
                    Posted by Bazyle on 15/07/2020 13:05:58:
                    Thanks Baz. So the V ie normal side handles flat pulley ok too ? How about Powertwist belt on the flat ?
                    #485913
                      Posted by Stu Oswald on 15/07/2020 20:02:59:
                      It is used that way in [probably millions of] Tumble Driers
                      Small Poly-Vee pulley at the motor; and the belt wraps either round the drum, or large flat pulley.
                      Steviegtr
                        @steviegtr
                        I know when i changed my Serpentine belt on a Renault trafic van. The dealer asked is it 5 ribs or 6. I said i'm not sure. The next question was does it have air con. Yes. So it needs to be the 6 rib belt. Without air con it only has 5. I take it the more ribs the more power it can handle. Best answer i can give to the question asked.
                        Steve.
                        #485933
                        oldvelo
                          @oldvelo
                          Hi Chris
                          Poly vee belts populate my workshop 4 PJ ribs up to 1hp & 6 PJ ribs on 2.5 sawbench.
                          Eric
                          #485935
                          duncan webster 1
                            @duncanwebster1
                            Can you re-machine the flat belt pulleys to accept poly vee properly? I do realise you'd need access to another lathe
                            #485938
                            Hopper
                              @hopper
                              I run a poly v belt on the flat pulleys on my old Drummond M type. Seems to work best with the vees contacting the pulleys. The back of the belt seems more slippery. From memory its an LK series belt about an inch wide.
                              Cutting the v grooves in the pulleys has been on the round tuit list for some years. Main advantage would be less belt tension on the bearings.
                              #485947
                              Dibnah
                                @dibnah
                                Posted by Michael Gilligan on 15/07/2020 21:30:43:
                                Yes of course it is…..Thanks for jogging my memory !
                                #485948
                                Dibnah
                                  @dibnah
                                  Thanks to other gents who responded, haven't got time to reply individually now but appreciate the assistance. Can you acknowledge a post with a like or thumbs up type click just to show appreciation ?
                                  #485953
                                  Bazyle
                                    @bazyle
                                    I'm led to believe that cows don't live forever. Leather beltig is available. I also have a length of some specialised rubberised modern belting but it has no ID marks on it. On another forum as an aside in another topic someone mentioned that they used fiberglass reinforced packing tape made up into a belt for a Southbend lathe.
                                    If thnking of making grooves in a pulley I would suggest starting with an aluminium casting.
                                    #485994
                                    colin hawes
                                      @colinhawes85982
                                      I have been using a toothed belt on it's smooth side to drive my Drummond lathe for years as I reckon it gives a better grip than leather and no changes in it's tension. Colin
                                      #486326
                                      Dibnah
                                        @dibnah
                                        Posted by Bazyle on 16/07/2020 08:29:30:
                                        yes Long live the cows. Cows lives matter laugh
                                        #486327
                                        Dibnah
                                          @dibnah
                                          Posted by colin hawes on 16/07/2020 12:11:10:
                                          yes Cheers Colin
                                          #486328
                                          Dibnah
                                            @dibnah
                                            Posted by duncan webster on 15/07/2020 23:38:31:
                                            Not at the moment …no but that could change as just been offered a Viceroy. It's like it's just starting to rain lathes in my life ! That can't be such a bad thing can it !? smiley
                                            #486357
                                            Martin Whittle
                                              @martinwhittle67411
                                              I have been looking at this myself, and thouroughly endorse Micheal Gilligan's recommendation of the Hutchinson Transmission website application to have a play around with power levels, pulley sizes, speeds etc, having had a play with this recently.
                                              My new application – looking at a belt drive conversion of a Warco WM16 mill. I am generally happy with this, but when I push it (not really that) hard, I get a severe 'shrieking' noise from the transmission area , no idea what this is (some resonance set up between the primary drive step down to the intermediate shaft and the secondary step driving the spindle?)
                                              So, as said I have been looking at belt drive, step down of 4:1 could be a bit of a problem, 5000 to 1250RPM for lower speed range, therefore requiring around 25mm pulley on the motor to 100m spindle pulley, and around 120N or more belt tension. So twice this + overhang factor on the motor spindle, around 240N plus 20%, so 30kg or 65lb sideways pressure on the motor end bearing (at 25mm driving pulley, 5000RPM, 0.7kW), Bit concerned about motor bearing.
                                              But for Bibnah:
                                              My 'middle sized' lathe is a Zyto, and iniitially came with a leather belt which was very close to falling apart at the clasp between the leather belt ends. Many years ago I replaced the belt by a Halfords poly-v fan belt, seen in photo, with ribs down onto flat puuley. It is a little slightly wider than pulley width – abolutely not a problem apart from being to wide for the smallest pulley / highest speed,step next to the bull wheel, which would be too fast a settiing anyway. The poly-v works very well on flat pulley for this light loading, and you absolutely do not need to machine your existing pulley to fit.
                                              Martin
                                              #486360
                                              Martin Whittle
                                                @martinwhittle67411
                                                PS you can get any number of ribs on the belt that you want – it apears the dealer just cuts the width you want off a wider belt of the standard length, although multiples of 4 are most common, Most common type for likely 'amateur' applications is the 'J section, 2.34mm rib pitch, I purchased a belt, £9.95 (seemed standard price for almost anything of similar style) with free delivery, from Bolton Engineering Products only today to play with – they have web and ebay sites (BoltonBearings).
                                                No link with the supplier beyond eager anticipation!
                                                For my application (700W motor, 25mm pulley, 5000RPM max) it appears a 4 rib belt is enough. Also good for for 1 kW with higher tension, but 1.4kW needs a 6 rib belt according to the Hutchinson application . My wood lathe, Axminster with 1.5kW motor, at lower speed (higher torque) and higher pulley diameter, (better belt wrapping/grip) uses a 10 rib belt.
                                                NB quoted 'belt width is often that of the pulley top including flat edge areas, not the belt itself, so the 4-rib part you might find having a quoted width of 13.5mm, not the expected 9.36mm. Pulleys found on the web are generally expensive taper-bore fittings, not what I want. So probably buying some 100mm diameter 6082 soon for a bit of machining!
                                                Martin
                                                #486383
                                                Dibnah
                                                  @dibnah
                                                  Posted by Martin Whittle on 17/07/2020 22:40:17:
                                                  Martin
                                                  That is definitely good to know and info about the belt sizing that followed. Thanks Martin
                                                  Edited By Dibnah on 18/07/2020 08:36:54
                                                  #486386
                                                  Dibnah
                                                    @dibnah
                                                    Posted by Martin Whittle on 17/07/2020 23:15:26:
                                                    Martin
                                                    You didn't say the length of belt you ordered for that price but this company might be worth bookmarking.
                                                    This size will suit me I think once I have moved things around a bit and it's only £2.78 delivered !
                                                    mark costello 1
                                                      @markcostello1
                                                      Slit many thousands of them.
