polishing spindle taper threads
Home Forums Hints And Tips for model engineers polishing spindle taper threads
  • #30508
    clogs
      @clogs
      clogs
        @clogs
        Hi out there……
        Decided to treat myself to a 30mm dia polishing spindle…..
        I have the shaft and bearings and a good friend just donated a 3hp, 3phase motor….
        so need to make the tapered threads, any idea's or just taper the shaft and
        cut the threads by hand…drudgery…..??
        many thanks Frank in France…
        #162372
          Was discussed a while ago in this thread
          #162408
          jacques maurel
            @jacquesmaurel42310
            #162414
            John Haine
              @johnhaine32865
              Convert your lathe to cnc, then it's a doddle….
              (ducks the brickbats…)
              #162416
              _Paul_
                @_paul_
                This youtube video shows "Doubleboost" making a taper spindle
                #162429
                _Paul_
                  @_paul_
                  And part two.
                  #162443
                  clogs
                    @clogs
                    HI again,
                    I did try the search function on the forum, sorry I wasted ur time……
                    Very pleased with the results tho…….quite liked the thread cutting arrangement on the u tube video….
                    yes I know I'm sad…hahaha…
                    thanks again..Frank in France……..just started the learning curve……
                    #162446
                    Douglas Johnston
                      @douglasjohnston98463
                      What a wonderful video, I loved the accent and the use of descriptive language when things went wrong at the end.
                      Doug
                      #162455
                      Nick_G
                        @nick_g
                        Posted by Douglas Johnston on 02/09/2014 09:15:16:
                        Doug
                        That was quite tame for him.! smiley
                        Nick
                        #162460
                        Jon Gibbs
                          @jongibbs59756
                          The thread Jason linked to was started by me.
                          I've since managed to turn a pretty reasonable pigtail mandrel using a neat little gizmo from a Hemingway Kit …
                          It's made it an expensive and time consuming solution but it's very satisfying when you eventually get there.
                          I turned the taper and cut the thread with the same effective tailstock offset (approx 8mm) but to get a steep enough taper it was only possible to cut it on a short section of stock which was then screwed onto a mandrel with a threaded nose.
                          I'll try to post some pics.
                          Jon
