Posted by Jon on 16/06/2017 00:36:00:
Spot on Thai.
Originally 28 years ago I had a cheapish 1/2hp 6" bench grinder. Slightest touch with thin mops motor slows and constantly waiting to pick up speed.
Got given an old 5" Wolf with 1/3 hp motor, half as bad as the Chinese cheapy but less power.
Do have a 3/4hp 8" Draper Chinese and that would struggle with small 4-6" mops and parts.
You have to buy either a Left hand arbor or Right hand harbour to fit the spindle.
Normally its just a case of removing existing wheel and guards and fitting the arbor and away you go.
Equally you could just use any 3000rpm motor and make the arbor.
Do have some where a Viceroy pedestal mop polisher came with 3ph 3/4hp motor that was ok ish, quality counts. Does sport a 3hp 3000rpm motor now what a transformation with 10" mops doing steel work and stainless to 99% mirror. Wont stop this one barely any speed drop with pressure on. As a compare takes 1/2hr that above 1/2hp would still be going at it in 40hrs+ no pun.
Hate mop polishing, aluminiums the worst and too easy to over polish.
Indeed.
Filthy, hard, sweaty job at the best of times. A good polisher can earn good money
All industrial off hand polishing is done using a double ended spindle with a THREE HORSEPOWER motor. They do not slow down for anything. And can break wrists, fingers and destroy components flung off at great velocity in a split second. But Christ they get a job done quick.
I speak from experience as i had a metal finishing shop in my previous life in England. These days i have a Creusen top quality linisher L/H side, polisher R/H side, bought in 03, sold at the time in their "Pro" range, but i'd describe it more as high end "hobby". Certainly would not/ could not earn money with it. I think it is 3/4" hp, the linisher is perfect, but it's under powered for polishing with 6-8" mops.
Edited By thaiguzzi on 16/06/2017 06:03:14
