Pocket Sundial
Pocket Sundial
Home Forums Clocks and Scientific Instruments Pocket Sundial
Viewing 25 posts - 1 through 25 (of 32 total)
  • #638812
      Here's an idea for a small but challenging project
      http://www.pocket-sundial.com/pages/how-it-works-sundial
      Explains the mechanical side, but not the engraving or other challenges!
        Martin Kyte
          @martinkyte99762
          Model Engineer had an article on building a portable sundial some years ago. Probably late 90’s early 2000’s.
          It had a built in compass to set orientation, adjustable dial for latitude and a nice turned wooden pedestal to sit it on a table.
          I part completed 2 but then got distracted and never finished them. Maybe I’ll dig them out and have a go. Trouble is I need to find the back issues of ME first.
          regards Martin
          #638833
          bernard towers
            @bernardtowers37738
            Could be an interesting project, but I am amazed at how they do it for the price ,that is if its made in Austria.
            #638845
            Nigel Bennett
              @nigelbennett69913
              Martin
              Is it Christopher Armstead's Phoeboscope you mean?
              If so, ME 3860 p558, 3862 p728, (1989)
              ME 3864 p20, 3885 p622 (1990) may be the ones.
              #638847
              Martin Kyte
                @martinkyte99762
                Pheoboscope doesn’t seem to ring a bell but I may be wrong and I’m fairly sure it would have been later than that.
                Thanks all the same for taking the trouble.
                regards Martin
                #638858
                peak4
                  @peak4
                  See P29 on of this pdf from The Sundial Society
                  "A UNIVERSAL HELIOCHRONOMETER MICHAEL LEE"
                  https://sundialsoc.org.uk/wp-content/uploads/bulletins/B2009%20(v021)/Bull021-4.pdf
                  Bill
                  Edited By peak4 on 23/03/2023 18:06:59
                  #638864
                  Journeyman
                    @journeyman
                    A pocket sundial by Michael Butterfield of Paris, similar to the image below, featured on the BBC's Bargain Hunt last week. Worth as I remember several thousand pounds.
                    So keep practicing your work too may be worth a fortune one day.
                    Georgineer
                      @georgineer
                      My brother had a pocket sundial when we were young, but for some reason it wouldn't work indoors.
                      George
                      #638926
                      Nicholas Farr
                        @nicholasfarr14254
                        Hi, here's my one which I bought from John Lewis many years ago for £9.95. It's not what I'd call pocket friendly, but is designed for the traveller, although it's more likely to be an ornament.
                        Regards Nick.
                        #639023
                        duncan webster 1
                          @duncanwebster1
                          Albert E Waugh's book on sundials has a chapter on portable ones, including a design offered for sale by the USA scouts association, but I can't find any modern reference to it.
                          #639025
                          Anonymous
                            Posted by duncan webster on 25/03/2023 00:24:58:
                            ……but I can't find any modern reference to it.
                            If "it" refers to the book itself, ABE Books have a few copies listed.
                            #639029
                            phillip gardiner
                              @phillipgardiner
                              Georgineer Tell me would it work of a night?.
                              #639034
                                Brian Baker 2
                                  @brianbaker2
                                  Greetings Phillip, yes it would work at night, but you would need a good torch to read it.
                                  Brian B
                                  #639047
                                  noel shelley
                                    @noelshelley55608
                                    Do you need the compass to know which way to shine the torch ?
                                    A properly designed and set up sundial is quite accurate, provided you allow for the equation of time( the monthly variation ) for those with an interest there are several books on the subject, Duncan has mentioned one. Noel.
                                    #639049
                                    duncan webster 1
                                      @duncanwebster1
                                      The 'it' I referred to is the pocket sundial, not the book.
                                      The book also tells you how to make a moon dial, no I'm not making it up!
                                      #639064
                                      Martin Kyte
                                        @martinkyte99762
                                        Posted by noel shelley on 25/03/2023 10:01:51:
                                        I’m given to understand that the French railways were still setting or at least checking station clock into the 1970s. Certainly the clocks from large houses would be set by sundial in previous centuries and many longcase clocks had the equation of time mounted inside the door. Some sophisticated clocks had duel chapter rings and other mechanisms to make setting to sundial time easier.
                                        regards Martin
                                        #639074
                                          Posted by duncan webster on 25/03/2023 10:10:50:
                                          … hence my post
                                          But if you are claiming that the book mentions the design [as opposed to a product] being offered for sale then my find is presumably of no interest.
                                          … Could you please [for the sake of disambiguation] quote the actual text from the book
                                          duncan webster 1
                                            @duncanwebster1
                                            It's the hardware that's mentioned, but the book is quite old I think. I can't find anything on the Web that suggests it's still for sale.
                                            #639093
                                              For anyone interested:
                                              https://en.wikipedia.org/wiki/Albert_Waugh
                                              Incidentally : This is readable for free, online:
                                              https://archive.org/details/sundialstheirthe00albe
                                              Edited By Michael Gilligan on 25/03/2023 16:42:29
                                              #639094
                                                Drifting only slightly off topic:
                                                This is very good **LINK**
                                                https://www.m-a.org.uk/resources/Vol-27-No5_Nov_1998_Time_for_some_mathematics.pdf
                                                Georgineer
                                                  @georgineer
                                                  Posted by phillip gardiner on 25/03/2023 05:27:46:
                                                  I believe so, but I couldn't see it in the dark. Besides, Mum wouldn't let us stay up late to see it.
                                                  George
                                                  #639196
                                                  Gerard O’Toole
                                                    @gerardotoole60348
                                                    I bought a garden sundial about thirty years ago at a hardware store. It was clearly a modern reproduction but I thought it would be be a nice feature in the garden..
                                                    Some assembly was needed and it was unclear which way the gnomon attached. However it all went together and I waited until noon, local time, and set in the garden aligned to north to give 12 noon on the dial. I returned a couple of hours later to check it and found it was indicating ten o clock. It was working backwards.
                                                    Of course without thinking the matter out properly, I assumed the error was mine and that I had attached the gnomon upside down. Needless to say that didn't fix it. The problem, probably obvious to you all, was that it was made for the Southern hemisphere .and was then copied and then mass produced for a garden decoration.
                                                    I returned it to the hardware store. The manager told me they had sold about a hundred of them and that mine was the only one returned..
                                                    I still don't have one in my garden.
                                                    Edited By Gerard O’Toole on 26/03/2023 16:07:51
                                                    #639199
                                                    John Haine
                                                      @johnhaine32865
                                                      On a work trip I once had a spare weekend in Sydney and a hire car. Off I went for an explore using the city map provided and got hopelessly lost. I couldn't understand what my problem was until I realised I'd been thinking the sun was in the South… Days befor Google Maps of course.
