This is great information, some of which confirms my doubts. I trust too, that having gone down part of this track before, I haven’t bored the socks off any of you gentlemen.
Put simply, I have of necessity, become a skinflint.
Yet, I’m conscious of “spoiling the ship for ha’p’orth of tar”, and since I won’t be making anything else, I want to do the right thing. Judging from the replies, it is also necessary for me to use more cyber `ink’ and put this current phase of my project into better perspective.
Before the clock is assembled for the last time (by me at least), I need to lubricate it in a couple of less accessible places, ie. the `click’ and the ratchet wheel inside the fusee, and also the main spring. Now clean, polished and lacquered, the fusee, great wheel and maintaining wheel are ready for assembly. It would be handy therefore, to apply lubricant to the ratchet so that these parts can be assembled and put to one side.
A ten minute job!
Although there have been a couple of reasons why the main spring needs cleaning, I no longer have the correct means of removing it from the barrel. In fact, I never have.
NB – IT’S TOO DANGEROUS WITHOUT THE RIGHT EQUIPMENT!
It has been suggested elsewhere, that I wouldn’t need to remove the spring from the barrel if I washed it in petrol, and then applied grease. If greasing is the better approach, it should be possible to apply a tiny `drop’ between each layer as I wind it. In view of the above, that will have to wait until after the clock is fully assembled
Gordon, I considered Vaseline, but it melts at about body temperature. Watching the clock dripping stuff could be embarrassing in a Melbourne summer. Then again there wouldn’t be much of it. With my limited knowledge in chemistry, I have to ask – Why should a grease based upon silicone or lithium cause concern?
Thanks for your comments about Vaseline, KWIL. Spraying on a lubricant is not an option for me, having spent time testing and applying shellac lacquer to the brass in the past few weeks. I could of course decant some onto a wooden toothpick, and poke that where needed. (And nowhere else!)
The pivots, pallets, and impulse bits require the absolute minimum of oil but, on this clock at least, they are always accessible. Advice from several quarters has shown me the way to lubricate the clock, and that using a minimal amount of clock oil is very important.
Thank you for your comments, Norman and Clive. I had the notion that a sticky grease would suit both the ratchet and the spring, and having `washed out’ a couple of camera shutters, I can appreciate the separation and migration of oil from cheaper greases.
Regards to all,
Sam
