Posted by Adrian R2 on 07/05/2020 11:44:38:
I've got some similar to these. I think the nipple only lubricates the swivel that copes with shaft misalignment, the actual bearings I suspect are pre-greased and sealed.
Edit, on the other hand if you google the serial number for the insert there does appear to be a feature that could be a hole into the race for lubrication….another new thing learned.
Edited By Adrian R2 on 07/05/2020 11:50:48
Hi Adrian R2, not exactly, this type of bearing needs to be used as a pair or with another fixed bearing. The swivelling is so the platform/s they are mounted on, do not have to be exactly parallel or exactly on the same plain with each other, saves a lot of machining costs, as a fabrication can be made and these just fitted. If you have wobble of the bearing in the housing due to shaft misalignment or anything else, it will soon wear the housing and the bearing will become sloppy. There is no reason for further lubrication between the bearing outer race and the housing, in fact you need a bit of friction between the two to stop the outer race turning in the housing when in use. All of these types of bearing inserts that I've ever seen, have a small groove around the peripheral of the outer race with one or more small hole into the inside of the bearing and the groove lines up with the position of the grease nipple location. The drawing in the technical data in the link, shows a small hole but not a groove, but these grooves are only shallow.
Regards Nick.
Edited By Nicholas Farr on 07/05/2020 14:46:27
