Please hellp
Please hellp
Home Forums Manual machine tools Please hellp
  • #11608
    david lockwood
      @davidlockwood10028
      Broken spindle
      david lockwood
        @davidlockwood10028
        Hello chaps unfortunately I had a dig in whilst parting on my Myford ML7 and now when I try to take a cut deeper than 25 thou ish the pulley spins round but the gear it drives stays still. I can not see a way to fasten them back together without damaging the gear. Is there a way this can be fixed? Any help will be greatly appreciated
        With thanks in advance (optimistically) David
        #44019
        mgj
          @mgj
          Ring Myfords and explain the problem.
          They can give you an answer on the spot, and will have parts on the way inside a day. (take credit cards too!)
          0115 9254 222 will get you reception.
          Might be worth slackening the belt a little? And grooving the top face of the parting tool.?  Must have been quite an impressive jam up?
          Edited By meyrick griffith-jones on 07/10/2009 18:26:26
          #44020
            From the Lathes.co.uk site, may be of help
            Unfortunately the assembly does contain a weak point: the 3-step aluminium pulley is only pressed onto the sleeve – and it is not unknown for it to become loose and rotate. However, if the assembly is stripped, cleaned and the pulley secured onto the sleeve with a slight smear of low-strength Loctite all will be well.
            Jason
            #44096
            david lockwood
              @davidlockwood10028
              Thanks very much. Now I just need to disassemble the thing
