Plated Morse taper
Plated Morse taper
Home Forums Beginners questions Plated Morse taper
  • #50969
    Frank Dolman
      @frankdolman72357
           Under another thread, John Coates asks what people think
         of a boring head he has found offered on the web.
           Going on the picture, it seems to have a chromium plated
         Morse taper shank.  In my very limited experience I have not
         seen one before.  Is it a good idea or a very bad one?  Could
         those who know please tell us?
      Frank Dolman
        @frankdolman72357
        #50974
        Michael Cox 1
          @michaelcox1
          Hi Frank,
          Chromium is very hard and wear resistant so, from this point of view, it is a good thing on a morse taper.
          #50976
          Circlip
            @circlip
            But idealy go for hard chrome plating. the people that do this usually grind the finished item to size.
              O I, Chrome is colourless, It”s the Nickel plating beforehand that shines and that’s soft chroming.
              Regards  Ian.
            #50977
            David Clark 13
              @davidclark13
              Hi There
              The problem with chromium plate is that it peels.
              Remember your bike handlebars when you were a kid.
              It is normally called flash chrome and is as sharp as a razor.
              By all means buy it if it is a good price but make sure you can change the taper for a non chrome one if it starts to peel.
              regards David
              #50978
              Circlip
                @circlip
                That’s why I pointed to Hard Chrome David.
                  Regards Ian.
                #50981
                David Clark 13
                  @davidclark13
                  Hi Circlip
                  Have you ever seen hard chrome after it has been deposited?
                  Looks nothing like chrome, is anything but smooth, takes a long time to deposit and is very expensive to get done.
                  Then it needs expensive grinding.
                  regards David
                  #50998
                  Circlip
                    @circlip
                    Read what I rote mate. Yes I have. Had to have my forks on my Italian motorcycle operated on in this way.
                      The Italians are fantastic designers and ingineers but can’t paint and definately can’t bl***y chrome plate.
                      Re-iterate, go for HARD chroming.
                       Regards  Ian.
                    #51320
                    Sub Mandrel
                      @submandrel
                      Another dustbin diving session today. two draper morse adaptors 3MT to 1 and 2 MT : )
                      Surface rust but otherwise really bright (brighter than my new ones), but it isn’t chrome but very fine ground steel.
