Plastic material for making casting patterns
Home Forums Help and Assistance! (Offered or Wanted) Plastic material for making casting patterns
  • #192429
    Stewart Hart
      @stewarthart90345
      Hi all
      I've seen some ware a plastic for making casting patterns on CNC machines, does any one know what this material is called and where you can purchase it from.
      Thanks
      Stew
      Stewart Hart
        @stewarthart90345
        #192430
        Brian Oldford
          @brianoldford70365
          Are you thinking of Sikablock? It's available from the likes of http://www.johnburn.co.uk/
          I use it from time to time in my professional capacity.
          #192431
          Stewart Hart
            @stewarthart90345
            Bloody hell that was a quick reply.
            That,s the stuff.
            Thanks Brian
            Stew
            #192432
              Hello Stew, I think they use polystyrene and polyurethane foam in industry.
              Brian Oldford
                @brianoldford70365
                Polystyrene is frequently used as a sacrificial pattern material. Useful for large-ish one-offs. OK for CI but other processes need to be added if casting steel or other materials where the carbon content must be controlled.
                Sikablock (and similar from other vendors) is just such a polyurethane material. It's available in a huge range of densities. The lightest has similar mechanical properties to Oasis that used by flower arrangers. The densest could be used to drive nails in with.
                #192438
                Sam Stones
                  @samstones42903
                  Stewart,
                  To add a little more to this thread –
                  Polystyrene – actually expanded polystyrene (or EPS) is a foamed thermos-plastic, which will melt when heat is applied. It is often used as a form similar to the lost wax or investment casting process, melting and burning off as molten metal is poured into the mould.
                  Polyurethane is generally a thermo-setting plastic, which therefore doesn’t melt when heated.
                  Try **LINK**
                  Sam
                  #194894
                  David Brandon
                    @davidbrandon24162
                    I use polyurethane foam for most of my patterns. I use 50 lb per cubic ft. Most signs are now carved from this stuff using 15 lb/ft
