Plastic abrasive sheet
Home Forums Beginners questions Plastic abrasive sheet
  • #45857
    Raymond Ascroft
      @raymondascroft71629
      Could someone identify an abrasive sheet I obtained about twenty years ago please. It is on a thin plastic film similar to acrylic is a pale blue colour and the abrasive is more of a polish grade than an abrasive a lot finer than 1200 wet & dry. I think it was made before diamond dust became widely used.
      Raymond Ascroft
        #45860
        Martin W
          @martinw
          Ray
          I don’t think this is the answer you are looking for but Crocus Paper was a very fine polishing grade abrasive but as expected on a paper backing rather than plastic but hey it was blue.
          Cheers
          Martin
          #45888
          Raymond Ascroft
            Hi Martin
            Thanks for that, I have the dark brown Crocus Paper on a cloth roll similar to emery cloth but the plastic sheet gives a better polished finish and the surface texture is different to Crocus Paper unfortunately I have only a small square of the plastic left
            Ray
            #46090
            Martin W
              @martinw
              Ray
              Again probably not the answer but 3M do a product they call Microfinishing Film Sheets. As far as I can see these product either come with a backing material for fitting to powered tools or in sheets. I have tried to copy their description from the 3M data sheets.
              Cheers
              Martin
              3M™ Microfinishing Film, 266L PSA Sheets
              Micron graded aluminum oxide resin bonded to a 3 mil polyester film backing. Open coat abrasive surface is coated with a dry lubricant to resist loading. Sold as discs & sheets with pressure sensitive adhesive (psa) backing.
              3M™ Microfinishing Film, 268L PSA Sheets
              Micron graded aluminum oxide resin bonded to a 3 mil polyester film backing. Sold as discs & sheets with pressure sensitive adhesive (psa) backing. Use wet or dry for finishing a wide assortment of workpieces.
              Edited By Katy Purvis on 01/06/2015 12:19:52
              #46355
              Raymond Ascroft
                Hi Martin
                Have been in touch with local tool supplier he is going to source a trial sheet 468l silicon carbide sheet, the psa backing should make it easier to use on an old surface plate will let you know how it goes .many thanks
                regards
                Ray
