After a while using one of the Chinese 6040 CNC router/engravers for a while I have come to the conclusion that I need a cnc lathe. I have found a fairly new Clarke CL430 that will do the job, having the advantage it's functionally identical to the lathe part of my Warco WMT300, so tooling will be common and I will only be confronted with learning 'Lathe CNC' and not the quirks of the machine. I now have to choose a controller etc.
Has anyone any experience of the Planet CNC controllers?
I am most interested in the 4 axis Mk3. I understand it can be run on its own without a computer having been set up correctly. I do hope this is actually the case – my workshop is unheated and I have an array of dead XP PC's to testify just how fast the conditions kill the PC's. It strikes me that a tablet can be used to load a SD card in the warm, then that used to plug into the controller.
I really want, as a long term goal, to control the spindle so I can engrave the surface of turned work using a router as an optional lathe tool. This means having cnc control of the spindle. Does anyone know if the Planet CNC controller will allow a lathe spindle to operate with a stepper drive (can one go fast enough?) or if I will have to be able to swap between the standard motor and a stepper motor? The plastic materials I turn can happily be turned at 950 rpm or a little less, and the power demand is usually less than 50W from the motor. I realise I will have to use ball leadscrews to eradicate backlash before this is possible.
Sorry if it doesn't make much sense at the moment. I am just starting to get my head around what is needed to convert the lathe.
Richard.
