Plain bearings in orbit
Home Forums General Questions Plain bearings in orbit
  • #88386
    Sam Stones
      @samstones42903
      Gentlemen,
      What is the term usually used to describe the condition when a shaft begins to whirl or orbit (instead of sliding smoothly), inside a plain bearing?
      It’s a noisy condition which is often cured with just a drop of oil, or a new bearing with a better fit.
      Sam
      Sam Stones
        @samstones42903
        Looking for the term to describe a noisy bearing
        #88392
        Springbok
          @springbok
          Shafted…!!
          #88402
          MICHAEL WILLIAMS
            @michaelwilliams41215
            Hi Sam ,
            Cyclic instability is correct though most people call it bearing knock .
            Several variants :
            (1) Stable continuous action – like epicycic gears .
            (2) As (1) but unstable – happens sometimes not others .
            (3) Either of (1) or (2) but incomplete – shaft moves back and forth around an arc only .
            (4) Stable discontinuous action – where shaft jumps from one side of bearig to other . Usually associated with crankshafts .
            (5) Chaotic – shaft just jumps around randomly .
            Some of the above are simple reponse effects like crankshaft pulling repeatedly in alternate directions and some are resonance effects .
            For each situation , and normal stable running , there is a different way in which any lubricant present flows in the bearing and forms the bearing cushion .
            Regards ,
            Michael Williams .
            #88403
            Doddy
              @doddy
              Eccentricity may manifest itself as shaft to bore mis alignment (STBM) and/or dynamic run out (DRO).
              Even with a good oil supply, high speed turbine shafts can suffer "oil whirl" leading to major vibration issues
              Eccentricity and dynamic run out a usually due to mis alignment, more a "sloppy fit" in this case
              #88421
              Ian S C
                @iansc
                The term here would be "Munted", which is another way of saying "stuffed". Ian S C
                #88448
                Nicholas Farr
                  @nicholasfarr14254
                  Hi Sam, maybe it could be termed as Axial Oscillation.
                  Regards Nick.
                  #88450
                  blowlamp
                    @blowlamp
                    Could be Oil Whip, Whirl or Bearing Flutter.
                    Martin.
                    #88461
                    Bazyle
                      @bazyle
                      The correct term is "Precession". A secondary definition to the more common association with gyroscopes and planets.
                      #88468
                      MICHAEL WILLIAMS
                        Sam's original question impied a dry running or trace oil condition .
                        To be clear – in any unstable bearing there can be two different sets of action going on :
                        (1) Those actions due to hydrodynamic effects in the oil film .
                        (2) Those actions due to the dynamics of the whole shaft and to the geometry of the bearings and journals .
                        In any practical situation (1) and (2) of course interact .
                        Purely for interest there is a variant of bearing instability where the shaft shuttles back and forth axially .
                        MW
                        #88502
                        Sub Mandrel
                          @submandrel
                          In my workshop I call that a 'precision running fit'
                          Ian S C
                            @iansc
                            Sounds like the big end on some of my hot air engines, I just call it free running, sometimes it does get a bit extreme, one did get to .020" on a 1/4" crank, Brass bush very little wear, unknown grade steel pin took all the wear. Ian S C
