Pixie feeder MEW 203
Home Forums Model Engineer & Workshop Pixie feeder MEW 203
  • #130272
    Reginald Alders 1
      @reginaldalders1
      Has anyone built the Pixie feeder from Mew 203 and how easy is it to put together .
      Reginald Alders 1
        @reginaldalders1
        Assembly of Pixie feeder
        #130290
        Paul Barrett
          @paulbarrett57424
          I built it after buying the printed circuit board. It is easy enough to build although the article does not quite explain it all. I found it very limited on the speed it would drive a stepper. I certainly could not get it to operate it as described in the article despite messing about with the program. I was also interested in the rotary table program thinking it would make a programmable indexer but in the end I bought a rotary table module from steve ward and built my own which does everything i want.
          #130317
          Reginald Alders 1
            @reginaldalders1
            Many thanks Paul. I also thought about using it on an indexing head to cut gears. I will probably not bother now . Does Steve Ward have a website
            #130323
            John Stevenson 1
              @johnstevenson1
              http://www.worldofward.com/rotarycontroller/overview/
              Steve Wards web site.
              This thread is also a good read.
              http://bbs.homeshopmachinist.net/threads/59781
              Edited By John Stevenson on 21/09/2013 10:52:22
              Edited By John Stevenson on 21/09/2013 18:31:22
              #130335
              Paul Barrett
                @paulbarrett57424
                Reg.
                I have just used the steve ward indexer module to engrave a new dial for my lathe. I wanted 100 divs which would be 3.6 deg or 3 deg 48 mins. With the indexer you can either set divs or degrees and it is so simle. I think mine worked out about £80 complete.I bought the module and keyboard from steve. got the case from rapid electronics and the stepper module from ebay. I fitted it all in the case and made my own overlay. I also stuck a 40mm fan inside as well as the heatsinks get a little warm. Power supply came from an old laptop charger.
                I have some pics if you are interested.
                Paul
                #130359
                Reginald Alders 1
                  @reginaldalders1
                  Paul. sounds like an bargain. do you have the link to Steve Wards website, I tried John Stevensons link but it didn't work. Could I have a look at the Pics
                  Reg
                  #130363
                  John Stevenson 1
                    @johnstevenson1
                    Link now fixed – sorry
                    #130409
                    Paul Barrett
                      @paulbarrett57424
                      Reg.
                      I have sent you a pm.
                      Paul
                      #130443
                      Reginald Alders 1
                        @reginaldalders1
                        Many thanks Paul i've looked at your pics and some demos on youtube so I have been on Steve Wards website and ordered the indexer module , All i have to do is find the time to assemble it when it arrives. Also many thanks John for your help . I will keep you posted when I get around to assembling it
                        Reg
