Hi David,
I don’t know if you have managed to improve your set up on your Number Nine or whether any suggestions were useful, however I thought you might like to see the piston made for the Waller engine today which is fitted with PTFE loaded yarn.
It is very easy to fit – The piston is 0.05mm down on diameter and the groove is made just slightly wider than the stock material to allow it to spread as it becomes compressed in the bore with the depth about .05 less than the nominal thickness.
I tapered the top of the bore very slightly with a hand scraper to help it’s entry and pushed it in using the drill press to apply very slight up and down ‘bouncing’ movements to get it to enter. As you can see the material was cut at about a 30 degree angle such that it was in the groove rather than across it.
It has provided a good seal but without a great deal of drag – I can move the piston up and down freely enough by hand but there is very good compression.
Don’t be too put off by the apparent grubiness – it begins quite white but soon picks up the slightest dirt on your hands!
I see Reeves do list it on their website but it’s a bit dearer than when I bought mine but then again what isn’t
Hope this is useful to you
Regards – Ramon
Edited By Ramon Wilson on 01/11/2011 22:38:21
