piston ring
piston ring
Home Forums I/C Engines piston ring
  • #2379
    Andrew Millar
      @andrewmillar40976
      Andrew Millar
        @andrewmillar40976
        Hi al.l made piston rings for my lynx engine out of cast iron ggg40 after heating to cherry red and letting cool the rings are still very flexible .Any rings i worked with in the past have been very brittle. Any advice will be apecciated
        #121957
          Thats SG iron which is a ductile iron, often used for castings where you don't want a brittle part like crankshafts and axles.
          I think the Din number you want is GC25
          J
          Edited By JasonB on 10/06/2013 19:27:20
          #122004
          Ian S C
            @iansc
            The last rings I made , were made from an old brake disc, after heat treatment they were more brittle than SG iron, but more springy, previous set of rings were made of SG iron, not too sure of them, but they are working. Ian S C
            #122036
            Andrew Millar
              @andrewmillar40976
              Thanks gays for all the help will get some S G iron and make some more rings and go from there
              #122038
                SG iron is what you have already used that is why they are flexing and not brittle, the ggg in the code indicates that you are using Spheroidal Graphite (SG) Iron
                J
                #122044
                Andrew Millar
                  @andrewmillar40976
                  Thank Moderator can get GR 17 cast iron from the people i get my material from ,will give that a go. Did try oil quench them in oil- this helped
                  #122046
                    Thats will be ideal, its what I use.
                    J
                    #122048
                    Andrew Millar
                      @andrewmillar40976
                      Thanks for your help will let you know how i get on
                    Home Forums I/C Engines Topics
