Here's a tip for anyone using commercial compression fittings on copper tube, which I guess would only be on larger locos, or on a steam launch like mine. They come with the wrong sort of olive, the ones meant for nylon tube, at least the ones I have bought generally did. It turns out these will sort of work on copper tube, at least for a while, but are likely to start leaking, usually in an awkward place to see. Of course I didn't know this at first!
The ones for nylon or plastic tube have a short taper on each end and then a step up to a larger diameter in the middle. The ones for copper have a longer taper at each end that meets in the middle.
If there is information in the 1940's ME about model size fittings, I probably have the issues here. I have some wartime ones, and a pretty complete collection from 1944 until covid started.
regards
