Posted by DrDave on 18/06/2018 18:48:38:
. Hence the need to use “thermocouple material” all the way to the cold junction. After this, copper is fine
Actually the 'cold junction' is almost a myth.
usually it's drawn as the inner part of the special connector.
If you connect the two wires at both ends, you won't have any voltage to measure…
The 'cold junction' is always going to include the measuring circuit which is probably going to include copper, tin and lead if old style solder), doped silicon and who knows what else.
This is from Maxim Integrated:
Somehow the makeup of the special connector is critical, but you can use a copper wires to take it to your carefully crafted differential amp!
What's magical about calling some point INSIDE the special connector the cold junction, instead of OUTSIDE it?
Lot's of smoke and mirrors around these precious connectors! As long as your connections are symmetrical in terms of materials and their temperatures are close (I'd love to see a 10 degree gradient sustained across an XLR connector that's carrying less than a milliamp of current…)
