Pictures in posts and font sizes.
Home Forums Beginners questions Pictures in posts and font sizes.
Viewing 25 posts - 1 through 25 (of 30 total)
  • #534563
    Phil Meaken
      @philmeaken46472
      Just to clarify, I use a laptop with Linux – no Windoze here!
      Probably a couple of daft questions here, but I cannot see how to add a picture into a post I’ve done.
      My pics are usually from text with .odt from LibreOffice but I can convert them to .docx or .bmp easily.
      Or .bmp from a scanner.
      The other question is, can the font size in a post I’m writing be changed? I find it far too tiny to see write and read and have to [copy] and [paste] with Arial 13pt using LibreOffice, as I've done here.
      Mike.
      Phil Meaken
        @philmeaken46472
        How do I …
        #534630
        Thor 🇳🇴
          @thor
          Hi Phil,
          Your pictures must be in .JPG format (you should be able to convert your .BMP to JPG using for instance GIMP), posting pictures is explained here.
          Thor
          PS  This was written in LibreOffice Writer and pasted into this post using Ctrl V on the keyboard
          LibreOffice Writer
          Text imported into ME forum post using the Word paste icon
          Edited By Thor on 18/03/2021 13:00:13
          #534634
          jon hill 3
            @jonhill3
            Phil raises an intersting point on font size as I have tiny fonts in the messege box. By the way Im using windoze 7 and Brave browser.
            #534663
            Phil Meaken
              @philmeaken46472
              Posted by Thor on 18/03/2021 12:47:32:
              Hi Phil,
              Thor
              LibreOffice Writer
              Thanks, Thor – I've kept the link and indeed I've always used (copy] and [paste] and composed text in LibreOffice.
              Mike.
              #534667
              Nick Clarke 3
                @nickclarke3
                Regarding small fonts there is an icon 4th from the right in the upper toolbar of the post editing window that looks like a rectangular bar in perspective or, if you have that kind of imagination, a pencil eraser.
                Selecting your text and clicking on this will publish your text in the standard size and font.
                #534668
                Harry Wilkes
                  @harrywilkes58467
                  I'm a Linux user and I just change the zoom size of the web page I'm viewing and currently use 130% this is the easy way. I have yet to find a linux photo editor I like so I either use smart phone to edit image or turn on my trusty windows pc and use PSP.
                  H
                  #534685
                  Russell Eberhardt
                    @russelleberhardt48058
                    Posted by Phil Meaken on 18/03/2021 10:33:09:
                    "My pics are usually from text with .odt from LibreOffice but I can convert them to .docx or .bmp easily.
                    Or .bmp from a scanner."
                    Install Xviewer which can be used to view a number of formats and you can save from it in .jpg format.
                    Russell
                    #534691
                    Fowlers Fury
                      @fowlersfury
                      Re. "The other question is, can the font size in a post I’m writing be changed? I find it far too tiny to see write and read and have to [copy] and [paste] with Arial 13pt using LibreOffice, as I've done here."
                      If you're one of the myopic dinosaurs like me using Windows and a wheeled mouse, then hold down the Ctrl key and rotate the mouse wheel.
                      #534694
                      Anonymous
                        Posted by Fowlers Fury on 18/03/2021 15:46:02:
                        Is it just me or does anyone else find the operation of this counter-intuitive? When I rotate the mouse wheel towards me I expect the text etc to "come towards me" i.e. get bigger. Instead it gets smaller. …. and vice-versa.
                        #534696
                        Phil Meaken
                          @philmeaken46472
                          Posted by Nick Clarke 3 on 18/03/2021 15:05:37:
                          Trying that now, Nick.
                          #534700
                          Phil Meaken
                            @philmeaken46472
                            Posted by Peter Greene on 18/03/2021 15:54:44:
                            I'm certainly one of those, but as my laptop is probably just as ancient, I use Linux and a floaty mouse!
                            #534702
                            Phil Meaken
                              @philmeaken46472
                              Posted by Phil Meaken on 18/03/2021 16:08:45:
                              It just says :Remove format" sad
                              #534705
                                Thor's post almost says it all:
                                • Posting pictures explained here.
                                • Only jpg can be uploaded, not bmp, gif, pdf for whatever
                                • The editor doesn't allow fonts to be changed directly, but you can paste fonts in.
                                Other info:
                                • jpegs are resized by the forum down about 500×600, and – if the orientation is wrong – only a moderator can rotate it, and only in a post, not the album copy. Otherwise, delete from the album, rotate at home with gimp, photoshop or another photo editor, and reload.
                                • Importing fonts by pasting them into the web editor can massively increase the size of the post because the font is copied as well as the text, and fonts can be be rather large. As posts are limited to a couple of thousand characters, and the font specification is part of the message, you may run out of space! The 'Remove Format' button (blue box, top line fourth from right' ) will remove alien fonts and other confusing format info that might have been copied from a word processor, and which sometimes messes up post layout.
                                • In the event of a cock-up, there's only about 20 minutes to correct mistakes before the owner is locked out.
                                The restrictions may be fixed soon because moves are afoot to upgrade the forum software.
                                The easiest way on Linux to convert images to different formats is with the imagemajick package. On ubuntu,
                                • open a terminal with ctrl-alt-t
                                • Type:
                                  • sudo apt update
                                  • sudo apt upgrade
                                  • sudo apt install imagemagick
                                Then:
                                does what's expected – convert
                                Explanation for Windows users terrified of the command line:
                                'sudo' means 'run the next command with administrator privileges'
                                'apt update' means 'make sure the list of available software repositories is up to date'
                                'apt upgrade' means 'bring the system up to date by applying any outstanding software upgrades'
                                'apt install imagemagick' means 'download and install the imagemajick software package'
                                edit pesky smileys!
                                Edited By SillyOldDuffer on 18/03/2021 16:36:37
                                #534767
                                Macolm
                                  @macolm
                                  If using Windows, for managing and processing images, Faststone Image Viewer is free, very easy to use, versatile and powerful. Navigation is similar to Windows Explorer, but double clicking an image brings it up in full screen. Then hover the cursor at an edge, and editing menus appear. To convert to jpg (or whatever) just use “Save as” to select saved image type.
                                  Advanced features include batch processing and renaming, and very straightforward tools to move (sort) images to one of several folders.
                                  There are a number of similar free image applications, but of these, I find Faststone the easiest and most comprehensive to use.
                                  #534836
                                  Russell Eberhardt
                                    Posted by SillyOldDuffer on 18/03/2021 16:34:23:
                                    • Type:
                                      • sudo apt update
                                      • sudo apt upgrade
                                    Then:
                                    Not sure that's the easiest way for beginners! Yes Imagemagick is a very versatile bit of software but is command line only. Perhaps an easier way would be to install Converscreen which acts as a graphical front end ti Imagemagick and will convert and resize almost any image format. Even works on Windows as well!
                                    Russell
                                    #534845
                                      Posted by Russell Eberhardt on 19/03/2021 09:31:10:
                                      • Type:
                                        • sudo apt update
                                        • sudo apt upgrade
                                      Then:
                                      Russell
                                      It's the great debate Russel. The advantage of a GUI is the operator doesn't have to remember a shower of options, and instead chooses menus, selects from lists, sets radio buttons, and fills in a form. And any decent implementation will provide good online help too.
                                      Nonetheless, provided you know what you're doing, command line methods often faster to invoke and more efficient in operation. They do away with a multitude of overheads, but unfortunately the command line does require the operator to understand the manual, which is often hard work. The big advantage of commands is they can be scripted, making it possible to fully automate complex processes. For example, from the command line, it's quite easy to select and convert groups of files. For example, creating a thumbnail gif of every jpeg on my computer would take weeks of manual pointing and clicking with a GUI, and minutes with the command line.
                                      Like all other tools, horses for courses, and ust as one wouldn't buy a lathe just to make one M4 sctew it would be daft to learn command line methods for occassional tweaks, But for many puropses the command line usefully powerful, and not as scary as it first appears. Lots of people still love MS-DOS…
                                      Phil Meaken
                                        @philmeaken46472
                                        Thanks to all, but most ways seem to need too much of a long-winded faff or need extra packages to be installed, so I'll just not bother with graphics until the ME software is updated.
                                        As for text, indeed I do most in LibreOffice and Copy and Paste into here.
                                        #534849
                                          Posted by Phil Meaken on 19/03/2021 10:04:50:
                                          Probably the wisest course of action.
                                          Russell Eberhardt
                                            "Nonetheless, provided you know what you're doing, command line methods often faster to invoke and more efficient in operation."
                                            Agreed Dave. When I first started using Linux (in the mid 1990s with Red Hat Linux) I spent many happy hours with the manuals and still occasionally refer to Blum's 800 page "Linux Command Line and Shell Scripting Bible".
                                            Russell
                                            #534866
                                            Phil Meaken
                                              @philmeaken46472
                                              Posted by Russell Eberhardt on 19/03/2021 10:35:21:
                                              Russell
                                              Russell, that book looks like just what I need, so I've ordered it via Amazon.
                                              The LibreOffice "Getting Started Guide" which I got a few years ago I found wasn't that good, albeit being quite long. If only it had an index …
                                              #534907
                                              Howard Lewis
                                                @howardlewis46836
                                                Looks like there is no hope of my being able to use Windows 7 to paste / import an image into a post!
                                                Can JUST manage to paste / import (whatever the term is ) to put an image into an Album.
                                                No wonder we dinosaurs became extinct!
                                                #534911
                                                Fowlers Fury
                                                  @fowlersfury
                                                  Howard – this is by way of an experiment as I no longer have Win 7 but it "should" work with any screen text or image. I wont know until I press "Post a reply" and see it !!!
                                                  1. I opened a blank "Post a reply"
                                                  2. I held down the right mouse button whilst dragging the cursor over the text in your letter above.
                                                  3. Then released the right mouse button and moved the cursor to the blank "post a reply".
                                                  4. Then, I used the standard Windows command of Ctrl + V [which means "paste"]
                                                  5. The captured text from your post then appeared.
                                                  6. In the top right corner there was a red arrow. Clicking on this created space above the copied text which is where I am typing this.
                                                  Howard Lewis 19/03/2021 16:20:38
                                                  4554 forum posts
                                                  9 photos
                                                    Message member Message member Ignore member Ignore member Send to friend Send to friend quote Quote quote Report
                                                  Edited By Fowlers Fury on 19/03/2021 16:36:00
                                                  #534914
                                                  Howard Lewis
                                                    @howardlewis46836
                                                    Thanks,
                                                    I must make a note of that!
                                                    Now to send it a friend (Me ) so that I can keep it safe.
                                                    Just Saved as WORD .doc
                                                    Edited By Howard Lewis on 19/03/2021 16:54:11
                                                    #534917
                                                      Couple of points about Fowler's cut and paste example:
                                                      • FF hasn't pasted an image, just text. As far as I know you can't meaningfully paste an image into this forum's web editor with ctrl-v. Instead, it's necessary to use the Image button, which inserts a link to an image hosted on another website, or the Camera button, which inserts a link to a picture in the Forum Album. The best ctrl-v will do is to create a link to the image on your home computer, and – unless it's been set up as a web-server – no-one can read the file.
                                                      • Actually FF's paste isn't 'just text', it copies the full HTML, which is why the formatting has gone wrong.
                                                      I'm hoping the forthcoming forum upgrade will support image pasting with ctrl-v in a natural way. Time will tell!
