Yes, normal.
Citric, Acetic, and Formic Acids are all weak organic acids, and some bacteria and moulds eat them. (So do people in that many fruits contain Citric Acid, and Acetic Acid, aka Vinegar, is a condiment.) They’re bio-degradable and gradually go-off. However, a bit of mould on top wouldn’t stop me using older acid as a workshop pickle. Change it when it stops working, smells, or the biology escapes from the bucket.
Sulphuric, Nitric, and Hydrochloric are all strong inorganic acids, pretty much deadly to all forms of life. They don’t go-off and are powerfully quick, which is a good thing industrially. Apart from Hydrochloric, they require special handling and licences, so probably more trouble than they are worth in a small workshop. Hydrochloric isn’t recommended as a pickle because it tends to leave Chloride ions behind, which can cause corrosion underneath paint and plating later.
Sodium Bisulphate is a good compromise: “Sulphuric Acid half neutralised”. Inorganic, doesn’t go-off, cause severe burns, need a licence, or more than sensible handling precautions. The original Harpic Toilet Powder found in every home was Sodium Bisulphate but the modern stuff isn’t, I think because accidentally mixing toilet Bisulphate with toilet bleach emits Chlorine gas , which is nasty.
