phosphor bronze  or aluminium bronze
Home Forums Materials phosphor bronze  or aluminium bronze
  • #579238
    Kevin Bennett
      @kevinbennett25223
      Hi Guys i am at the stage of making the parts for brazing on a steam boiler
      do i need phosphor bronze or aluminium bronze
      Thanks Kevin
      Kevin Bennett
        @kevinbennett25223
        #579242
        noel shelley
          @noelshelley55608
          Gun metal ! or a normal Cu/Sn alloy ! Phosphor bronze is for bearings, and aluminium bronze is a high strenght alloy. Noel.
          #579247
          duncan webster 1
            @duncanwebster1
            Ally bronze is VDiff to drill and tap, and not at all easy to silver solder. SAE660 or Colphos would be my preference
            #579249
            Nigel Bennett
              @nigelbennett69913
              On no account use aluminium bronze on a boiler. Although technically speaking it can be brazed using special fluxes, you can't guarantee perfect sealing with it.
              #579251
              norm norton
                @normnorton75434
                You should be using PB102 bronze for boiler bushes (PB1 is acceptable) that are silver soldered to a copper boiler shell. The other bronzes mentioned contain lead (gunmetal LG2 5%, colophos 90 4%, SAE660 7%) and zinc, and there are reports that this can affect the silver solder joint. I think the Australian code says something about it but I am speaking from memory.
                For a boiler to be tested the materials used should be certified.
                However, I am sure that the use of gunmetal has been common, especially for turrets, and I would guess that people have been using colophos and SAE660 with no apparent failure. Some suppliers sell 'phosphor bronze' without being aware of the differences.
                Edited By norm norton on 08/01/2022 15:00:51
                #579278
                noel shelley
                  @noelshelley55608
                  I'm glad you said should be certified rather than shall be Norm ! For boilers built to standard or recognised plans for small ish boilers there's no requirement in the UK under club rules Etc. I've not heard of anyone here talking about the arsenic content of copper supplied to the ME trade for boilers Etc. Noel
                  #579281
                  duncan webster 1
                    @duncanwebster1
                    DataSheet for SAE660, note 'brazing good' 660
                    info from Noggin End 'contrary to popular belief Colphos can be silver soldered' colphos
                    Extract from AMBSC acceptable materials bushes, Alloy 836, which is near as dammit the same as colphos in chemical composition.
                    #579457
                    Kevin Bennett
                      @kevinbennett25223
                      Thanks for the info i will have a good look for the best action
                      thanks Kevin
                    Home Forums Materials Topics
