Petrol proof adhesive
Home Forums Materials Petrol proof adhesive
  • #370970
    AJW
      @ajw
      Made a start on my new Edgar T Westbury’s Centaur engine project. Started with the base, an aluminium casting with a large cavity underneath. As well as supporting the engine it acts as a fuel tank, the base of which it is suggested to bond in an alloy blanking panel.
      All well and good I thought so have been cleaning up the casting and have prepared a piece of 1/8 in ally sheet ready to fill the base.
      I was going to use Araldite to fix it in but am not sure about it liking being in full time contact with petrol or use something else?
      Alan
      AJW
        @ajw
        #370973
        John Rudd
          @johnrudd16576
          There used to be a product calledd "Petropatch" for car petrol tank repairs… May be suitable if still available marketed by Grenville iirc..
          #370975
            I've stuck several similar model fuel tank covers with JBWeld Original (red & black tubes) and have not seen any signs of it degrading.
            Edited By JasonB on 08/09/2018 19:54:46
            #370979
            Ron Laden
              @ronladen17547
              Araldite chemical metal would be better than standard Araldite epoxy, Devcon do a good range and as Jason suggests, JBWeld is very good and fuel proof.
              Dont know if it is true but I was once told that the rapid set adhesives are not fuel proof but the slower set time types are.
              Ron
              Edited By Ron Laden on 08/09/2018 20:47:04
              Edited By Ron Laden on 08/09/2018 20:49:05
              Edited By Ron Laden on 08/09/2018 21:01:21
              #370980
              Trevor Crossman 1
                @trevorcrossman1
                Most epoxies cannot be relied on for long term 100% resistance against petrol based fuels with the exception of those which are specially formulated for the construction of composite fuel tanks and they tend to be more expensive than standard lay-up epoxies, MAS is one such resin available from http://www.ecfibreglasssupplies, though I doubt that you would want the stock quantity. A better alternative for such a small task would be to use an aviation standard fuel sealant PR 1440 which is a virtually indestructible synthetic rubber compound and will resist attack from all forms of gasoline and its additives, it can be obtained from Light Aero Spares or other aviation suppliers, maybe you might know an aircraft maintainer who could get you a small amount.
                Trevor.
                #370981
                  That's why I said the "Original" JBWeld as the faster cure ones don't have all of it's properties and I have heard the same said of Araldite.
                  Few of its properties listed here including petrol Proof
                  Edited By JasonB on 08/09/2018 20:53:27
                  #370996
                  AJW
                    @ajw
                    Thanks guys, I have milliput and nowhere in its writeup does it even mention any type of fuel so I am thinking perhaps not. I also have some original JB weld which once again does not mention any fuel exposure.
                    Edgar himself suggests Bondafiller but unfortunately I think this particular product has disappeared over the years.
                    The rubber compound sounds good, will look into that, I guess not to be confused with silicone rubber which swells enormously!
                    Alan
                    #371005
                    AJW
                      @ajw
                      Just had a thought, at the last ally pally exhibition I was very impressed with some demonstrated aluminium solder. Seemed to give a good fillet, just the sort of thing i am after. Having a thumb through the bay there appears to be quite a selection of aluminium soldering products
                      Anyone had any experience of any?
                      Alan
                      #371022
                        AJW did you not read the link in my previous post where it says "When fully cured, J-B Weld is completely resistant to water, gasoline, and about every other petroleum product or automotive chemical"
                        Edited By JasonB on 09/09/2018 06:58:48
                        #371030
                        Ron Laden
                          @ronladen17547
                          Posted by JasonB on 09/09/2018 06:58:36:
                          +1
                          I once used JBWeld original to repair a hole in a motorcycle fuel tank where the adhesive was in direct contact with the petrol (hole was in the bottom of tank) and it was a permanent fix, never a problem.
                          #371040
                          AJW
                            @ajw
                            Jason apologies for missing that, I wonder why it’s not put on the packaging and instructions?
                            Sounds like a solution – I shall update Edgar!
                            Alan
                            #371042
                            Benjamin Day
                              @benjaminday94198
                              just to chime in and say the aluminium solders are very good….big grin on my face when i saw it worked. there are some Russian flux brands that work really well with the stuff too
                              #371063
                              Pete Rimmer
                                @peterimmer30576
                                JB Weld (not the quick one) is advertised as 100% resistant to petrol once fully cured.
                                #371077
                                AJW
                                  @ajw
                                  I have just had another look at my pack of original JB Weld and it makes no mention at all of fuel suitability?
                                  Strange as I would have thought that would be a good selling point.
                                  Alan
                                  #371081
                                  Ron Laden
                                    @ronladen17547
                                    Sounds as if you are not convinced Alan, despite Jason having sent you the JBWelds spec sheet….?
                                    #371088
                                    AJW
                                      @ajw
                                      Yes, convinced and I am currently using it as I have for the past few years just find it surprising that it’s not on the pack!
                                      Perhaps it is on a new pack, mine is quite old.
                                      Alan
                                      #371090
                                      Ron Laden
                                        @ronladen17547
                                        I dont know if its mentioned on a new pack or not but it made me think of one or two items I have used over the years which I always associate with a particular job. You then eventually read the spec sheet and learn that it can be used for much more.
                                        Ron
                                        #371094
                                          A sometime member here and contributor to ME and MEW has the soft jaws of his chuck stuck on with JBWeld, does not come into contact with petrol but shows that it is sticky stuff. He also tried some pipe joints as you would find on a model stationary engine upto about 300psi which is when his test pump would not go any higher.
                                        Home Forums Materials Topics
