hi I’ve recently acquired a Perris lathe, identifies with help from a forum member. It is a basic model with no screwcutting or traverse mechanism. I would like to bring it up to a better spec.and need some help.
If anyone has one I need the DP of the gears and gear count, initially for back gear operation. I do have the gear that is connected to the drive pulley. Also need the size of the mounting hole in the gears and any other info. that will help me. I do have access to another lathe and a mill and have cut several gears before.
