Two things to check before using these in an engine – 1. max temperature of operation 2. PV factor with the kinds of pressure caused by piston forces , and the velocity range, in an IC engine or high speed steam engine (you don't mention what type of engine you will be making).
I think you will find that all metal bearings of some sort will be needed, rather than PTFE lined shells.
