Graham,
I had a 'play' with my plasplugs multi grinder yesterday. The drill holder is clever but imperfectly realised, although it's simple design does make a decent job of holding the bit at the same height for each flute.
Drills are ground at the top of the wheel, and the grinding is more or less normal to the cutting edge.
The setting jig has a triangular steel 'ramp' that sets the bit protrusion. A moveable 'V' at right angles to this sets the drill orientation by a four-point contact. You can use this as a check for symetrical grinding.
Drills are presented to the wheel with the bit turned slightly to the right, which more or less puts the cutting edge along a radius near the top of the wheel. An invisible, but presumably off-centre, pivot creates the backed-off edge as you turn the holder.
The weaknesses of the design are two fold – the tiny 70W motor struggles to keep the grinding wheel going at speed under any sort of pressure – so it's best for worn, not damaged, cutters. Secondly the plastic construction and some spindle end play mean you need to develop a consistent 'touch'. regularly turning the drill 9rather than doing one side at a time helps. The Tip angle seems to be accurate.
I suspect it would be worth duplicating the jig in metal.
Does anyone know how the sharpeners that have a drum with various holes for the drills to be poked into work?
Finally, anyone seeking the digital article (or other digital content) on MHS will be delighted to know that the effect of a system reset that rendered all digital editions 'out of stock' has now been rectified.
