Taking the Polly Model Engineering Sheet Numbers or Description in the order in which I made the parts
Sheet 3 :-
Spring Buckle: The 0.149 dimension should be 0.156 minimum to match the radius on the spring Link
Axle box suspension Bracket: The lug is not positioned side ways. It should be positioned to match the hole in the keep plate i.e the centre line of the lug should be .309" from the upper edge
Sheet 10 Valve Gear
Roller die Block: R0.819 should be 4.625
Rocking lever: INA Bearing should be SCE 2-1/2-4
Crosshead link: Diameter 0.125 should be 3/16" to match pin
Crosshead: should incorporate 3/16" Phospor bronze bush.
Sheet 11 Valve Gear Parts & Layout
Eccentric Rods: Upper Rod needs csk pin to avoid fouling Suspension lever bracket..
Weighshaft: Dimension missing, distance between centres of lifting links = 1.431"
More to follow
