Can anyone assist me with a penetrating sealant that will be effective in the following circumstance?
A model outline "submarine" where the 4inch diameter wooden bow section slots into a 4inch diameter drainage pipe. The joint is screwed and then sealed with a rubberised gasket sealant and was a sound waterproof joint when created. I then "plated" the hull with shim brass sections fixed with epoxy resin. I thought that this would result in a belt and braces waterproof seal. After further work on the boat a flotation test has revealed a small leak in the joint and from the amount of water entering I guess would probably amount to no more than a pinhole. An attempt at stopping the leak on the inside with more rubberised gasket predictably met with failure.
In conclusion, somewhere on the lower hemisphere of the joint mating surface circumference there is a tiny leak which has to be retro-sealed as dismantling the joint is no longer an option. The question is how? Any ideas on an effective penetrating sealant?
Mick
Edited By mick H on 12/05/2021 08:35:17
