Pendulum suspension spring problem
Home Forums Clocks and Scientific Instruments Pendulum suspension spring problem
  • #238440
    Rod Neep
      @rodneep80388
      My wife has a lot of faith in me…. "I moved the clock that you bought for our anniversary 20 years ago, and now it doesn't work. Can you mend it?"
      It took me quite a while to find out what was wrong (I know virtually nothing about clocks). It would tick if the pendulum was removed, but not with it fitted. Then I noticed that there is a tiny spring (just a single flat leaf) at the top of the pendulum arm that appeared to be broken.
      The spring is held at the top and bottom by small "plates". The exposed spring length is about 5mm long…. I presume that the spring comes with the plates attached…. but where can I get hold of one?
      You can see here that the spring has snapped perfectly in half.
      Edit: Hmmm…. were there two springs, each about 3mm long, held between the plates? Each broken where it meets the plate.
      Thanks
      Rod
      Edited By Rod Neep on 12/05/2016 15:44:48
      Rod Neep
        @rodneep80388
        #238441
        Ajohnw
          @ajohnw51620
          Probably here or Cousins
          Roger Woollett
            @rogerwoollett53105
            You might find this link to Cousins website easier to use.
            Get the bits out of the clock and measure between the two holes. 'B' on the website.
            roy entwistle
              @royentwistle24699
              Meadows and Passmore Or you can open the brass cheeks out (remove the pin first) and measure the springs or try 3 thou feeler gauge ( This can be cut with scissors ) Note If your missus reads this I didn't suggest it
              Roy
              Ps  Never move a clock with the pendulum attatched
              Edited By roy entwistle on 12/05/2016 16:29:32
              #238507
              Rod Neep
                @rodneep80388
                Thanks… I ordered it from Cousins.
                Thanks to you folks I will have preserved my wife's confidence in me as a genius who can mend anything
                Rod
                #238803
                Rod Neep
                  @rodneep80388
                  Just to report…. the clock lives!
                  …. and I have just heard that sometime during the next couple of weeks the cardiology specialists are going to do a similar, but rather more complex time-keeping operation on me. I am having a pacemaker/defibrillator unit fitted.
                  Cheers
                  Rod
                  #238806
                    Congratulations, Rod
                    .. and my very best wishes for the cardiac work.
                    Do try to get an electronic unit ; I understand that the pendulum ones can make walking difficultdevil
                      Best wishes for the op., Rod.
                      #238949
                      the artfull-codger
                        @theartfull-codger
                        I've made a few of these mainly for long case clocks & I use the spring that's at the end of a tape measure ie stanley or lufkin, I look after our towns turret clock [gillett & bland] & the suspension spring snapped about 15 yrs ago so I machined a new one from an old panel saw, I first bent the saw both ways & it went back straight so I knew it was good spring tempered steel & machined it down to the right thickness,making sure it was cut lengthways & it's been in ever since, when you think about it it swings millions of times each year.
                        Graham.
                        #238951
                        Tim Stevens
                          @timstevens64731
                          I have had about 40 years service from a bit of razor blade in a Vienna Regulator. The holes needed were punched over a piece of wood …
                          Cheers, Tim
