Gentlemen, I realise that this is a very old thread but I have found in the box that the "contact file" was in, yet another peculiar needle file.
This has an overall length of 90mm and if you look carefully the cutting portion of the file is approximately 55mm long. The tip measures 0.5 x 1.5mm and it tapers to approximately 1.25 x 2.5mm, the cut is extremely fine, it barely makes any mark on brass (haven't tried it on steel) and I can barely see a mark when running it across a finger nail. Using a 10x magnifier l can't find any markings on the plain portion ie handle.
Have any of you any ideas what this could have been for? I did think that it might have had a clock/watch connection but I've not been able to prove/disprove this idea.
Phil
