Posted by Jelly on 24/03/2023 23:09:19:
Posted by Mick B1 on 24/03/2023 20:01:02:
Posted by Jelly on 24/03/2023 18:50:29:
Posted by Mick B1 on 24/03/2023 14:23:48:
I actually quite enjoy feeling the tool cut under handwheel control, and like Nigel McBurney above, have never seen manual lathes or capstans in production using powerfed partoff – my suspicion is that it's done mainly for bragging rights by the exponents.
That seems like an entirely unnecessary snipe aimed at making yourself feel big by doing others down for their perceived motivations rather than adding anything useful to the discussion…
I'm not bothered by return fire
. I can't see a practical role for powered partoff in the sort of quantities typical in model engineering, and where other parts of the cycle aren't also automated.
I'll give you a very practical example:
Next week a friend is coming over with a short length of 170mm Hastelloy C22 bar, because he wants me to turn him two DN50 blank PN40 flanges.
There's barely enough material to make them and even if I could fit it on my bandsaw it would not cut well or straight, if at all.
So I need to take an 82.5mm deep parting cut through a notoriously awkward nickel-chromium superalloy…
That will stress the lathe enough as is, there's zero chance of me maintaining sufficient or consistent tool pressure and feed rate through a cut that long feeding by hand; at which point Bang! Broken insert, if not broken parting tool, and quite possibly a £900 piece of material ruined.
Well, you've picked a considerable outlier to the normal range of model engineering components, in size, difficulty of material and cost . So, is powered partoff just another extreme sport?
My own view is that manual feed provides a flexibility, and an awareness of any issues developing during the parting cut, that I don't think you'd get from doing it under power.
The biggest, thinnest thing I can remember parting was some side flanges for toothed-belt wheels I was making for a subcontractor to Ford's toolroom in the late '70s. I had the dishing problem I mentioned above, and sorted it with light facing cuts in soft jaws. Can't remember whether I lost one through not having left enough excess, but if I did I had enough of the 5 or 6 inch bar to replace it.
But hey, as is often said on here, no-one can tell anyone else how to do summat, only how they think they'd do it.
And yes, with material like that and a tight quantity, sooner thee than me!
