Parting Off MEW225
Parting Off MEW225
Home Forums Model Engineer & Workshop Parting Off MEW225
Viewing 25 posts - 1 through 25 (of 291 total)
  • #176657
    KWIL
      @kwil
      I am looking at page 8 of MEW 225 with Reg Merryweather's article on Parting. off in the metal lathe
      There is a drawing error on Fig 5 in that the parting tool should be inverted and to the right of the workpiece, but hey-ho these happen.
      Notwithstanding that I thought I would simulate the same procedure of mesurement on a 40mm diameter setup.
      When I apply a large turning force to my chuck by means of a bar inserted into thechuck  key hole the maximum dip I incure is 0.0028" (c..f.Reg's 0.0190" and with the movement towards the headstock, less than 0.0010" (c.f. Reg at 0.0140"
      My parting blade is a flexible blade with carbide insert, mounted in a QCTP, the DTI is a 0.0001" resolution Mercer.
      I do not have a digging in problem but I would like to find why my results are so different from those presented in the article.
      Edited By KWIL on 20/01/2015 10:23:29
      KWIL
        @kwil
        #176666
          That's how the drawing was supplied and it illustrates the measurement the author made.
          The differences could be down to lathe type or the individual setup. I am not convinced the place where the toolpost is attached to the slide is critical – if the toolpost and slide are very rigid and effectively act as one lump of metal. Reg may have a less rigid setup, and that may be why it works for him.
          I think the real question with rear toolposts (which obviously do work) is that in use they try and lift the rear of the cross slide off the bed. This puts pressure on a normally no-critical bearing surface and also they apply a large twisting moment at the front guide acting to separate the main bearing surfaces, the opposite of the normal action. The lower front bearing surface has to take the largest load of all,.
          Should be a recipe for disaster, but it isn't – why?
          A second thought – surely in normal turning the forces on the tool are the same as on a front mounted parting tool…
          I am sure the parting debate will run and run!
          Edited By Neil Wyatt on 20/01/2015 11:05:10
          #176669
          blowlamp
            @blowlamp
            Posted by Neil Wyatt on 20/01/2015 10:59:45:
            Because the swarf falls out of the groove by gravitational attraction smiley instead of piling up on top of the cutting tool until a log-jam is formed. This is why jams never occur in the early stages of parting-off, but the deeper the cut, the more potential there is for swarf to become trapped between tool and workpiece.
            Martin.
            #176670
            Muzzer
              @muzzer
              I don't think there is any great mystery. It must be simply down to the design of the actual machine and the severity of the load. If you take a very light cut with a razor sharp tool you will barely load the machine whereas if you take a full cut with an indexable tool, you are going to want the saddle to be fully constrained against being lifted by the cutting forces.
              Never owned a Myford but it seems they can tolerate moderate upward loads in typical ME useage. I've looked at the design of my Bantam and there is no obvious means of constraint. Interestingly, the Colchester rear toolpost is designed for operation of the machine in both directions although I haven't bothered getting one.
              Personally, I don't feel the need for a dedicated rear toolpost, as I can swap tools quickly easily with the QCTP and keep the machining area clear of projecting tools – surely that is its primary benefit? However, I often machine parts with the tool behind the centre line (usually a boring bar), with the machine running in reverse. TBH, it seems to me that if you are going to make use of a rear-mounted tool, you may as well run it in reverse and keep the tool loads in the direction the machine was designed for.
              Murray
              #176679
                Kwil I wonder if you nice M300 has anything to do with itwink 2
                Neil as you say the loads when turning are the same as when parting but how often do you take a 3mm depth of cut which is basically what a 3mm wide parting tool is doing. A lot of hobby lathes would also chatter etc taking that sort of cut with a turning tool.
                Edited By JasonB on 20/01/2015 13:12:09
                #176683
                John Stevenson 1
                  @johnstevenson1
                  Posted by JasonB on 20/01/2015 13:09:09:
                  Aahh you mean a finishing cut ?
                  #176699
                  Speedy Builder5
                    @speedybuilder5
                    I haven't read the article, but users should be aware that if you have a chuck which screws onto the headstock, it can unscrew when parting off with a rear toolpost and reverse rotation of the chuck.
                    If you use an inverted blade and rear tool post with normal chuck rotation, then you would suffer the same amount of chatter as using a normal too post ?
                    BobH
                    #176701
                    KWIL
                      @kwil
                      Jason,
                      All measurements made on a properly adjusted Myford Super 7.
                      Did not try the M300!!smiley
                      Swarf entrapment is not a problem with insert tooling, the shape of the insert makes the swarf narrower than the kerf, so entrapment is not a problem.
                      Edited By KWIL on 20/01/2015 16:15:43
                      #176704
                      blowlamp
                        @blowlamp
                        Posted by KWIL on 20/01/2015 16:15:12:
                        Jason,
                        Agreed, and that's why they can be employed as usual in the front toolpost without problems, plus the blade is quite a bit narrower than the insert which gives clearance there as well.
                        Martin.
                        #176788
                        mick
                          @mick65121
                          Wish I had a fiver for every time there's a thread on parting! Using a rear mounted parting tool there's no need to reverse the motion as the tool is inverted, you only reverse when using an inverted parting tool in the front tool holder and yes this could spin the chuck off under some circumstances.
                          #176795
                            Posted by Speedy Builder5 on 20/01/2015 16:13:54:
                            Bob,
                            … only if your "normal" toolpost is mounted direct on the cross-slide
                            I think the main cause of problems is that the top-slide introduces another layer of flexibility.
                            P.S. … The Gibraltar ToolPost looks a very sensible design … Can anyone offer a review?
                            Edited By Michael Gilligan on 21/01/2015 18:56:04
                            #176804
                              I have a sub-Gibraltar toolpost for my mini-lathe that fits on the t-slotted slide. A simple cube of meehanite that has a twin-screw t-nut to attach it and takes the standard toolpost on top. It's very good but annoyingly I got the height slightly different so I have to use different shims for each tool :-/
                              sub - gibraltar toolpost.
                              #176822
                              Danny M2Z
                                @dannym2z
                                Nice T-slotted topslide for the mini-lathe Neil.
                                Any more details? – Enquiring minds need to know!
                                * Danny M *
                                #176824
                                  Neil assuming you made the bit of iron too small then why not cut a shim the full size of the block and fit it under the toolpost so you don't have to use two sets of shim for each tool?
                                  J
                                  PS it would have looked better painted yellowwink 2
                                  #176826
                                  Roger Williams 2
                                    @rogerwilliams2
                                    John Stevenson, as a bloke who does it for a living, and must have parted off hundreds of times, what are your thoughts on the subject ?. For instance, do you use power feed ?. Thanks.
                                    #176828
                                      Yes – if you want to keep your sanity, don't do it. I chewed it out of a block of CI making the bottom to match they existing slide (plus recess so it can come further back over the index) and then three t-slots in the top.
                                      Would be an easy job on a mill, but I used a taig/peatol vertical slide…
                                      Jason
                                      I hate unsecured shims, actually with most tools it takes a 1/16" shim so it's not a big issue.
                                      The green is good old Humbrol Brunswick green I use for various home-made accessories I do have a full tine of (old formula) yellow smoothrite that matches the lathe and one day I will do a full repaint!
                                      More pics here
                                      Edited By Neil Wyatt on 22/01/2015 09:40:26
                                      #176833
                                      Ian S C
                                        @iansc
                                        My theory for jamb ups when parting is that the side of the tool wears a few thou, more at the tip than further back(more use), and when a deep cut is made in one go is when the danger occurs, hense the idea of taking a second cut to widen the slot. This is with HSS tooling, carbide tools should be no problem.
                                        Ian S C
                                        #176845
                                        Gordon W
                                          @gordonw
                                          I was asking for help re parting-off only a couple of years ago, but here is what I have found, – My lathe has 3/4 hp motor but not really enough power for parting steel with an insert tool. HSS tool ground with side clearance and 2mm wide or less work well. But cannot have top rake ground or the clearance is lost. I ground a bit more front clearance and tilt the cutter to get some top rake. Like IanSC I take an extra side cut to widen the groove when needed. To me it seems obvious that the more joints they are in the set-up the less rigid it will be. I have been looking for a bit of heavy steel to make a one piece toolholder and not use the top-slide. I don't have slots on the cross-slide, just 2 x 6mm bolts to hold top-slide or toolpost, so need a flange for mounting,hence steel so it can be welded up solid. Do not use shims if possible, one thick one if must, just an extra 2 joints. Slow speed, slower than normal, just to keep down vibration which is difficult to stop once started.
                                          #176869
                                          KWIL
                                            @kwil
                                            Gordon,
                                            Which lathe do you have? I can chew through steel with only 3/4 hp motor using inserts on a Myford Super 7 running around 400 rpm,
                                            #176872
                                            Gordon W
                                              @gordonw
                                              Chester DB8, older belt drive ( which I like ) 8" dia. max. The toolbit is 3mm wide I think, can't get at it now. No roof and 2" ice. 400 revs ok at 1" dia maybe but 200 better ie less vibration. A "V" section tool is easier on steel. I 'm not into mass production tho'. Every thing is better if all gibs etc. are tight but not always very practical.
                                              #176926
                                              “Bill Hancox”
                                                @billhancox
                                                Posted by Neil Wyatt on 21/01/2015 21:08:36:
                                                Thanks for that. I have a slightly oversize 4X tool holder that is slightly to tall for my Myford Speed 10 tool post. I will now attempt to fit it to my cross slide. No suitable meehanite available locally so I will give it a go with some 1018 mild steel.
                                                Cheers
                                                Bill
                                                #178397
                                                Kiwi Bloke
                                                  @kiwibloke62605
                                                  I can't believe I'm reading the confusion in this thread… The late, lamented George Thomas wrote pretty much all anyone could ever need to know about parting off (and many other topics) in his many comprehensive Model Engineer articles and his books. Perhaps it's time for a re-run?
                                                  Merryweather's article is BAD and MISLEADING (yes, I'm shouting!). It may not be his fault – perhaps it has been mangled by editing or production errors, but it doesn't belong in anything with aspirations to be an authoritative journal. As printed, his explanation is faulty. What determines in which direction a tool is deflected under cutting loads is the relationship of the direction of the resultant force on the tool to a line joining the cutting tip to the centre about which the tool and its holder, toolpost, etc. can rotate. (By rotate, I mean move by flexing. It will certainly flex – nothing is infinitely rigid, and Myfords certainly ain't!). A rear parting tool, inverted, with the lathe running in the 'normal' direction is successful at avoiding dig-ins because, as it is loaded, it tends to be deflected up and away from its point of contact, thereby relieving the forces upon it. Just think how it would move if its toolpost were hinged to the cross-slide. Similarly, but the opposite, for parting-off with a tool in the 'normal' toolpost.
                                                  The article is not clear. Merryweather's Fig. 5 bears no relationship to the photos of his toolholder set-up. I THINK he must part off with his lathe running in reverse: there seems to be chip build-up on top of the tool (photo 3). This, of course, isn't a good idea for lathes with screw-on chucks… If this is correct, photo 3 suggests that the tool and holder will be deflected clockwise, pivoting about its mounting to the cross-slide, and therefore relieving the cut, as load is applied. If this is the case, the set-up could be reversed, with the tool-holder mounted 'in front' of the spindle, and the lathe run in the 'normal' direction. It is, in fact, more-or-less a re-invention of the 'spring tool' (look it up), although rather less springy….
                                                  Another reason given for the success of rear parting-off tool-holders, especially on non-rigid Myfords, is because the tool loads lift the cross-slide, minimizing dovetail clearance, and tighten-up the whole shebang, reducing chatter likelihood. This doesn't apply to inverted-vee beds, of course.
                                                  #178447
                                                  jason udall
                                                    @jasonudall57142
                                                    My apologies if this has already been covered ( trials and tribulations of parting off do crop up from time to time)
                                                    If ones cross slide is set to face off concave
                                                    . ( again done to death)..
                                                    Then the front mounted partoff tool will try to follow this tool path…
                                                    Now any tendancy to move sideways while parting off is fraught with trouble.
                                                    Aha you say but the rear mounted tool will also crab sideways…in this case to wards the head stock ..
                                                    Now the headstock end of the cut is well held so might tolerate this..but the sideways movement in the front mounted tool is adding load to the poorly supported and driven part. ..
                                                    Can’t comment beyond that since I tend to use dedicated partoff slide not slaved to cross slide…
                                                    As to using a rear tool post…..well a tool post dedicated to partoff ( even if on cross slide) will probably ensure more consistent tool height setting..and the forces also tend to compress the post rather than lift ..and I suspect the post’s performance is better in that respect.
                                                    So there are two possible reasons for improved performance in partoff with rear mounted tool….
                                                    Oh and there’s swarf clearance…patently better with gravity rather than against..
                                                    #178448
                                                    jason udall
                                                      @jasonudall57142
                                                      Incedently..if tool crabs sideways towards headstock. .that would. Improve situation in the FRONT mounted tool..
                                                      Which is the situation for those who have crosslides that are set for concave facing…
                                                      So I don’t know what conclusion that leads one to…
