Parting off – Left over nib
Home Forums Workshop Techniques Parting off – Left over nib
  • #781992
    Blue Heeler
      @blueheeler
      Is there a way when parting off to have the left over nib (that at least I always get) stay on the piece that’s in the chuck and not on the piece that’s been parted off?
      I’ve tried adjusting my parting tool every which way over the years and never managed to have that nib not end up on the parted piece.
      Anyone have any hints?
      Colin Heseltine
        @colinheseltine48622
        Nikcole Mini Systems do some very nice parting and grooving tools the indexable carbide tips are as thin as 0.7mm and can be obtained for right hand or left hand holders. The actual tips can cut a flat bottomed groove or can cut minutely tapered so the pip can be on the part held in the chuck or on the piece parted off.
        I am very impressed by them and I use the 8mm square holder on my Cowells lathe. I have the next size up holder for use on Myford.
        #781996
        Blue Heeler
          @blueheeler
          Just Googled them Colin, nice looking tooling but they only make micro cutting tooling?
          #781997
          howardb
            @howardb
            The traditional way to grind a parting tool, either made from square HSS tool bit stock, or a HSS parting tool blade is to grind the tip of the tool to a slight angle, so that the “pip” is left on the bar stock in the chuck, rather than on the workpiece being parted off.
            The slight angle can be 10-15 degrees on a short stumpy parting tool, but on the blade-type don’t go more than about 5 degrees or the angle can deflect the blade sideways, resulting in the parted off face on the workpiece being concave.
            #782031
              If you go with Nicole then get a handed parting insert rather than a flat bottomed one.
              If you are using GTN style inserts then the N is for Neutral, you can also get R & L depending what side you want the pip left on. Same for most other types of insert, get the handed ones if you want the pip on a particular side
              Both these have the same effect as grinding the end at an angle. Only down side is that it can make the cutter more prone to wandering off to the side
              #782037
              Bo’sun
                @bosun58570
                Concur what howardb says.  Keep the angle and blade stick-out as small as possible.  Even so, still check for any curvature of the cut face if it’s important.
                #782039
                Nigel Graham 2
                  @nigelgraham2
                  Another problem by excessive angle across the tool face is the chip being wider than the cut, so more prone to jamming.
                  Many insert tools have a Vee-profile to curl the chip inwards and to give a better rake angle to the cut; and though that will not prevent leaving a pip on the parted-off piece, that is usually the lesser problem
                  #782105
                  Blue Heeler
                    @blueheeler
                    Cheers one and all, appreciated.
                    #782133
                    Wink Hackman
                      @winkhackman25989
                      Is there a UK supplier for the Nikcole inserts and holders?
                      #782135
                        MSC Direct, though they now brand them under one of their own makes.
                        #782179
                        Colin Heseltine
                          Yes there is a UK supplier for Nikcole.  They have a larger variety of stock than MSC.
                          Newcomer Ltd.,
                          Black Horse Road,
                          Coventry,
                          CV7 9FW
                          Tel: 02476 363535
                          Ask for a lady called Nina in Sales, she was very helpful.  Tell her they are for hobby use, helped on prices.
                          Colin
