It is the lack of rake that makes life easy. I only use 4 deg (in the main) because I have toolholders that hold the blade at the optimal 4deg, so the top is ground flat and the toolholder does the rest. Grooving and everything else is done with zero rake.
I don't like having a rear toolpost fitted because on a small lathe it gets in the way, for me anyway. The only reason I tried it, was because of parting problems, and it offers no advantage – and you wouldn't expect it to. If one resolves the forces the diagram is exactly the same, front or back, and in particular the backlash space is on the work side of the feed nut either way round. (One day I will get round to making a backlash eliminator of the Myford! It has been on the to do list for 10 years now!)
So the concern is a component of the force on the cutting tip acting to drag the tool tip forwards into the work: if you have positive rake such a force exists by definition, and if you have negative rake such a force doesn't exist. But clearly some positive rake is helpful in promoting a nice clean cut and a good finish. But not too much. Hence limiting it to around 4deg.
That's for general purpose steel, but more grabby materials like bronze and copper need to be treated differently and the recommended angles are different. I normally use a commercial tip for them, because of the negative rake: that works without getting too involved with specialist tools.
DMB – the decent tapered Eclipse H5 blades are available – at a price. MSC do them. Interstate seems to be pretty good too. Seems to be a lot of "HSS" around much more cheaply, but it is I find, rather useless.
Edited By mgj on 28/06/2021 11:00:54
