i broke another brand new carbide parting tool (brazed, but commercial quality) last week. I think that the major problem in the home workshop,is that we try to push the envelope right to the very edge of what is possible, but I still broke it, and I know why! It broke, because the bar moved in the chuck, because I was making a bush for a pulley on a short end of mild steel, and the remains wasn't long enough to fill the chuck jaws. In industry, this bit of steel would have gone in the scrap bin (and I would have got it out and "repurposed" it in industry, they would have been using a collet chuck, not a three jaw with an ever so slight bell mouth! You need a full tight chuck with a good grip of the material. You need to lock the carriage, you need a properly ground tool, on centre height, in a rigid tool post, in a rigid machine, with a powerful motor and a good deal of "grunt" or you need a tool designed to stop the inevitable "dig in" if something goes wrong, like a rear tool post, upside down tool in reverse, or a swan neck tool holder. Sure, it works in industry, because industry has the time, and the skilled staff to make it work, and ultra high quality rigid machines to do it on. We are not in industry, we need to abide by all the above rules.
The day before my disaster, with the same tool, I had parted of the end of a cast iron pullet about 2" diameter with a 1 1/4"bore. Worked perfectly, no problems, and emboldened by success, I ploughed in to the mild steel with a less than good grip on the bar (and the situation!) I shall repurpose the broken parting tool as an external, 60 degree threading tool, and continue trying to perfect my parting off skills. I will do it………………..but I won't enjoy it
