Posted by jason moore 1 on 19/04/2013 09:00:03:
Now that you have got your ml4 to turn diameters parallel try machining a bore to the same standard.
With the work piece held in the chuck or on a faceplate of course, not with a boring bar between centers.
If your lathe can do this you are as jammie as a jammie thing covered in jam!
An ml1 owner.
Edited By jason moore 1 on 19/04/2013 09:04:01
Hi Jason , it does bore true over a depth of 50mm ,I've found it helps If you take a few ' spring cuts ' befor you get to your required I/D
