I have recently moved my Myford to paint the cabinet and remove all the swarf that had collected ‘down the back’ – couldn’t believe it!
I found this very awkward and top heavy.
I have made small ‘skates’ for each foot. Each foot now has 2 wide nylon wheels to enable the lathe to be ‘rolled’ out – when in position bolts are screwed down through the new skates onto the concrete floor for staabilisation and leveling – seems to work well
Anyway after all this I checked for twist in the bed and managed to do the lathe feet up with about .00025 twist, measured over a 18 inch bar. The lathe bed feet are in fact pieces of 10mm studding nutted into the top of the cabinet so the lathe bed is ‘elevated’ above the cabinet by a couple of inches, this enables the bed fixing positions to have a nut/washer top and bottom and makes for simple setting.
Turning a 9 inch length of bar between centres I found the tailstock end to be 3 or 4 thou larger than the headstock end. After about an hour of adjustment and taking a few thou off I have now got this down to about .0005 over a 7 1/2 turned length – is this a typical figure?
The lathe is an ML7 bought in the early 50’s but well looked after.
